Download usb floppy disk driver on windows vista
I can not download on my computer the driver of usb floppy disk drive, the model of the external unit is SFD-321U/EP and my lap top has windows vista, thenk you
  • Anonymous Nov 01, 2008
    usb floppy unter vista geht nicht
  • 69 Answers
Have you try to download the driver from this link ?
http://www.bestdrv.com/samsung_sfd_321u_ep_driver_83033.htm
Posted on Sep 06, 2009
I have a USB floppy disk drive that is not working in my pc
Windows 10 does not have floppy disk drive support for internally installed floppy drives. USB drives should work. I have a TEAC external that works just fine with WIN 10.
Floppy Drive support in Windows 10
Nov 18, 2016 | Computers & Internet
Tip
Which Windows Vista Edition are you?
If you are upgrading XP to Vista, make sure you backup and have the program "Windows Vista Upgrade Advisor"
Download Windows Vista Upgrade Advisor:
http://www.microsoft.com/downloads/details.aspx?FamilyId=42B5AC83-C24F-4863-A389-3FFC194924F8&displaylang=en
Be Sure to Backup with a removable media such as CD's, Floppy Disks or USB Flash Drives, External Hard Drivers.
Windows Vista Editions:
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Business
Windows Vista Ultimate
Windows Vista Starter
Windows Vista Enterprise
These also include 64-bit.
Lastly, if you have XP and if it's Vista Capable, you don't need to use the upgrade advisor, you are allowed to use any, but you must download the drivers after upgrade.
on Mar 14, 2009 | HP Pavilion dv2000t Notebook
I have a emachine netbook and it say no bootable device
Failed hard drive (assuming one is installed), or could be that it has "lost" the Windows installation.
Possibly a virus, you need to reinstall windows, or hopefully, repair the installation
To do this, as this does not appear to have a DVD rom, you will need the following:
  1. A legit copy of windows (whichever is installed currently)
  2. A spare computer or preferably an external USB DVD Drive (if the latter, skip to the end)
  3. The SATA drivers for this laptop (essential if using windows xp, may not need if vista)
  4. a USB pendrive of at least 4 GB
  5. A USB Floppy drive (possibly)
  6. a copy of win to flash
http://wintoflash.com/home/en/
Uisng the spare computer, extract the contents of the Windows disc to a folder on the spare computers hard drive. Run win to flash and follow the instructions, it will build a boot copy of windows on the pendrive that you specify (it will format the pendrive also).
Copy the sata drivers to the USB floppy drive (you might get away with copying them to the same usb bootable you have just made but I doubt it)
Now, in the bios, set 1st boot to USB drive
Then boot and install, when you reach the F6 prompt, point it to the usb floppy drive and let if find the sata textmode drivers.
Its hould then find your existing windows installation and repair it
IF you ahve a USB DVD / CDROM drive, ignore the above and just install from that, you may need to use a floppy usb to install the sata drivers though
Feb 08, 2011 | Acer eMachines eM2501162 Netbook
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
I have a gateway m285-e and can't get XXp Sp2 to recognize the Hard drive. How do i fix it??
hi guy
just follow this guide it'll help you
fisrst of all get the driver from here :
http://support.gateway.com/support/drivers/getFile.asp?id=20455&dscr=Gateway%20Notebook%20Computer%20Intel%20SATA%20Support%20DriverVersion:%205.5.0.1035
then follow this guide
Note: Installation of this driver requires the use of a floppy disk drive. If your computer does not have an internal floppy disk drive, an external USB drive can be used instead.
Download the driver file to the desktop, and then perform the following steps.
1. If you have not already done so, locate and double-click the D00455-001-001.exe file that you downloaded from the Internet and execute the file. Files extract to the C:\Cabs\D00455-001-001 folder on your hard drive.
2. Insert a blank floppy disk in the floppy disk drive.
3. In the C:\Cabs\D00455-001-001 folder, double-click F6flpy32.exe.
4. Click OK to start the disk creation.
5. The disk creation dialog box closes when the disk is complete.
6. During the installation of Windows you will need install this SATA controller driver. Press the F6 key on your keyboard to install a third party controller driver.
7. The Windows installation program requires the use of a USB floppy disk drive and the floppy disk that was created above.
8. The Windows installation procedure attempts to load the drivers twice; once directly after the F6 selection, and a second time after the installation files copy to the hard drive.
9. Select the "- Intel(R)82801GBM SATA AHCI Controller Mobile ICH7M" option as listed.
Note: To find the required selection it may be necessary to scroll down even though there is no indication to scroll down.
Note: If you experience any recognition errors during the installation, please reference this Microsoft Knowledge Base article KB916196. This article explains which USB floppy drives are supported by the Windows installation process. http://support.microsoft.com/kb/916196/en-us
Removal
Because the computer must have these SATA drivers when using a non-Gateway supplied operating system, these drivers are necessary and should not be removed.
just let me know
Oct 15, 2009 | Computers & Internet
HP DV2700Tx Windows vista to XP Downgrade
you will need to download the SATA controller driver from
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&cc=uk&lang=en&os=228&product=3641490&dlc=en
without that your laptop won't recognize your hard drive there
are 2 ways to solve this:
first one you'll need an external floppy drive save the sata driver on a floppy put your xp disk in and start the install at the very begining xp prompts you press F6 to install sata driver press that and it'll get the driver from the external floppy drive.
second way is to create an xp disk with the sata driver to achieve that you'll need a deployment software i use nlite
http://www.nliteos.com/ if you have any problems add me to your msn messenger atlascomputerrepair@hotmail.co.uk and i'll talk you through it
May 03, 2008 | Panasonic U7500 Notebook
USB external floppy drive
In windows XP and later the USB mass communication driver are in built, so you can use these devices like USB Floppy drive, USB HDD, Memory card, flash memory etc...
But before windows XP Microsoft did not supply the driver for USB mass storage devices. So, in your case you have to install the Driver for your USB Floppy drive, then you can use this drive as Floppy drive but after complete boot of your Windows 95.
If any problem or more question Just Ask me
Thanks
Iqbal
Apr 07, 2008 | HP Compaq Business Notebook NX9010
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Panasonic Toughbook CF-27
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
Oct 26, 2007 | Panasonic Toughbook CF-27 Notebook
Changing the drive letter
If im not mistaken, you need a RAID driver for this model. I don't recall, but does this thing have a floppy drive built in? Or do you happen to have an external? You might be able to use the cdrom to complete this, never tried this way, in the event you dont have a floppy drive.
Visit this page - http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1363702&rpn=PPM41U&ct=DL&BV_SessionID=@@@@0308016801.1193190290@@@@&BV_EngineID=ccchaddmflilldicgfkceghdgngdgmm.0
Download the RAID driver relevant to the OS your going to install. Let's say for XP. After downloading, extract the files in the archive. You will find a folder named Drivers. The files in that folder, need to go on a floppy disk. If you dont have a floppy disk, you may need to make a trip to your local computer store and pick up a USB Floppy drive.
Insert the XP install cd. When the screen turns blue you'll see an instruction to load a third party driver at the bottom of the screen. It says to hit F6. So once the screen turns blue, tap the F6 a few times.... XP will eventually ask you for a driver disk, at this point, you insert the floppy disk into the floppy drive. And hit S in order to specify additional devices.
The rest is pretty easy from there. You should be able to continue on and install windows.
The reason it doesn't see the drive, is because Windows does not recognize the Raid controller that the drive is connected too. Thus, you need to load the driver for it from the F6 funtion during the OS setup. Have questions, let me know.
Oct 24, 2007 | Toshiba Portege M400-S4032 Notebook
Computers & Internet Logo
772 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
