Question about Amana ARB8057C Bottom Freezer Refrigerator
Amana ARB8057C upper fridge not working
Hi
The bottom freezer is working but the upper fridge portion is not. I've just finished defrosting the whole unit as an initial approach. The freezer "radiator" had a tiny bit of ice buildup but nothing to indicate a problem. The air pathway where the fan is located in the freezer is OK. The output in the fridge portion is OK and not blocked either. Perhaps a couple of tips as to how to troubleshoot would be great
  • Anonymous May 25, 2009
    Upper Fridge not working..Freezer ok
  • Anonymous Mar 28, 2014
    the fridge portion doesn't not work. the freezer works
On further inspection, I noticed that the fan in the freezer was not spinning. I was going to check the voltage on the fan motor but then I noticed that the spindle on the fan motor as actually spinning but the blade was not. The blade is made of plastic and had come detached from the spindle. Therefore no cold air was been pushed up into the fridge compartment. I pushed the blade into the spindle (after power was turned off) and everything was back to normal. Unfortunately this is probably going to happen again because there are no bolts holding the blade on the spindle (an engineering flaw) but at least I'll be able to locate the problem much faster next time.
BTW: The fan assembly is usually hidden behind plastic shrouds. You need to remove shelves and take off a few screws to see it. Hope this helps others .... I suspect this fan assembly is used in millions of fridges and is a major revenue generator for fridge repair folks.
Posted on Jul 01, 2008
Freezer blowing air but getting warmer and stopped making ice. Fridg also seems to be warming up. no unusual noise.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. But if the freezer also gets warmer it can be failure of the auto defrost making the vents choked. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 20, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
The top portion of both the freezer and fridge are warm but bottom half are freezing.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 27, 2010 | Amana ARSE66MB Side by Side Refrigerator
Freezer building up frost refrigerator not cold
the main problem is it's not defrosting. there are two things to look for first unplug the fridge and take the back wall off of the freezer. 1/4 inch screws. next in the upper right hand corner of the freezer there is a disc with two wires coming out of it. probably brown and red/orange. see if it looks whole not exploded. if you cant see it cuz of to much frost use a turkey baster and hot water and put on in the area of the thermostat disc, if the disc is whole then next would be the defrost timer, but i would try this first. very common problem with the amana.
Nov 24, 2010 | Amana ABB1927DE Bottom Freezer...
My fridge is running but the top portion is not cold. The freezer seems to be working appropriately though. what should I do?
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
Not cold in refrigerator, but freezer is fine
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Feb 27, 2010 | Amana ARB8057C Bottom Freezer Refrigerator
Refrigerator not cooling
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Amana ARB8057C Bottom Freezer Refrigerator
Amana ARB8057C Bottom Freezer Refrigerator Logo
145 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
