Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Time and Date Setting
When ever i start computer the Time and date automatically go back to 3rd April 2006 and Time 12.03AM, i change it and again when i start the computer later on. the date and time changes to 2006 one.
  • Microsoft Master
  • 2,794 Answers
There is a lithium battery in your computer that needs to be replaced. If you open up your coumputer, look for a round looking battery about the size of nickel.
Posted on Jun 30, 2008
How do i change the time
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Nov 08, 2017 | The Computers & Internet
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
Date error
Change the date back before the 14th April and you can play again. To be able to use the current date (date after 14 April), you have to update the firmware of your R4 card.
There is one available for the R4iSDHC version 1.16B.
Apr 16, 2010 | Nintendo DS Lite
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Daylight Savings Times Changed
Oct 29, 2007 | Emerson Smartset Clock Radio
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
