Question about Samsung LN-S4692D 46 in. LCD HDTV
Box right in the middle of my tv-
I was told by my cable people that the box in the middle of my tv displaying not available in the current mode, is the caption box I went in the menu i cant shut it off
  • 31 Answers
Make sure it is turned off on the tv and the cable box. if that dose not fix it it may need a main board
Posted on Aug 14, 2008
Sharp tv won't display cable picture (it only shows fuzz) but the netflix and DVD both work. The cable says no input service available. I am able to change the channel on the cable box, but on the tv
Your cable box might not be sending signal out to the tv. Would have to call service provider to have them test your box. Or, you can try unplugging your cable box, and then plugging it back in. Make sure all connections are secure and settings on your tv are accurate. 11_13_2013_3_31_52_pm.png
Aug 11, 2013 | Televison & Video
Connecting Sony Vaio to Samsung TV
The problem is the cable. Those converter cables rarely work. they can't translate the scan rates properly. You need a converter box for the video signal, and get a cable to plug into the headphone jack on the laptop to send sound to the audio input on the TV. Here's a link to an example of the type of box you need to get the video working.
Hope this helps!
Joe
Apr 07, 2017 | Acer Aspire 5102WLMi Notebook
How do you change dma for xp to default
1.
Open Device Manager.
2.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
3.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
4.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
• Change the selection from "DMA if available" to PIO only, and click OK.
• Then repeat the steps above to change the selection to DMA if Available.
Sep 23, 2009 | Microsoft Windows XP Home Edition
Onkyo Tx SR606 Listening Modes "Not Available" Via Optical I have my Sky+ Box plugged directly into my TV with an optical cable from Sky box to my 606. I had no problems changing the listening modes untill...
check to see if the DIRECT icon is illuminated on the panel...if so, cancel the DIRECT function. This is only a thought, also check HDMI settings as well as optical mappings...
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Samsung LN-TFT-LCD Television
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Jul 31, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
When vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
Audio and video track are not in sync
I guess that your CDROM Device doesn't have DMA (Direct Memory Access) enabled.
From the Microsoft Knowledge Base Article:
To enable DMA mode using the Device Manager
1.
2.
3.
4.
Oct 14, 2007 | Computers & Internet
62hm195
It sounds similar to my Toshiba 62HM195 that I posted about except my screen is spit down the middle and my bottom half is messed up but the upper half is Ok.  I have been told it is a bad Light Engine Part # 23405481.
Oct 07, 2007 | Toshiba 62HM195 62" HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
