Question about Fujitsu 24C1 Air Conditioner
Lingth of line
What is ment by maximum hight difference? I have a total of 70' of run with a 25' lift. (model ASU24CL). How does affect your over maximum pipe length?
    Novelist:
    Champion:
  • 230 Answers
The length of line set can dramatically effect the efficiency and operation of the air conditioner. There is a science behind the design and application of the different sizes. Refrigerant carries oil in it as well as the refrigerant itself. The length can change the amount of oil that is supplied to the compressor. The length of pipe can change the indoor coil's ability to flash to vapor gases.
The instructions that came with your unit should be able to simplify this for you. There will be minimum and Maximum lengths and possibly even some graphs and tables to study.
Posted on Jun 30, 2008
Fujitsu unit outdoor model AO54UJBMR central controller flashing EO 25. PFC over current. Carried out a power reset. running current is 20.2 A unit is drawing 20.2A. How do I diagnose this fault?
If you are drawing the running current then you are at maximum current and this is likely causing the trip off, increase the available line current reading, rewire it or run 220 volts AC if it has an option for that voltage. use that voltage..
Oct 27, 2016 | Fujitsu Heating & Cooling
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Size difference between 275/70/18 and275/65/18
It also depends somewhat on the brand and model of tire, but just a little. There should be somewhere around a 1/2 inch difference in tread width. Why is the lift important?
Nov 24, 2013 | Vibrant 275" 2Bolt Exhaust Gasket...
My fax machine is recognizing my home number which is line 1 in our house. I need it to recognize line 2
No fax machine holds your address. You can enter your fax number which is called the csi (caller station ID) and your Name (ie company name) called your TSi (transmitting station ID). thats all. Some machines will let you have multiple TSI's for different departments. I have never in 25 years on working on faxes ever heard of one holding an address!. The maximum amount of digits you can enter ranges from 15 to 30depended on make and model.
Srri
May 15, 2011 | Canon Office Equipment & Supplies
Pump will not pump water, its runs
Hi and welcome to FixYa. I am Kelly.
If this is a new system installation there can be a few reasons for the pump not pumping water.
1. The most porbable cause is that it is sucking air on the suction line. Check to make sure each and every connection it a good sealed connection.
2. The pump having never had water in it may have to be primed by introducing water into the outlet hole or remove the impeller housing plug and prefill the cavity with water.
3. There should be a check valve or a foot valve with screen at the very end of the suction tube.
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/agdex1143
Limitations
Jet pumps lose efficiency as the total lift increases. Total lift includes the vertical distance from the water to the pump plus the friction losses in the suction line and foot valve. Shallow well jets are not practical if the total lift exceeds 5.5 m (18 ft).
Pumping water containing sand will cause wear and leakage around mechanical seals. The mechanical seal on the pump shaft is water lubricated and water cooled, so the pump should never be run without the pump casing being filled with water. Air or gases in the pump will cause a loss of prime. Shallow well jet pumps must have either a check valve or foot valve installed on the suction line to maintain prime.
Foot Valve:
http://t3.gstatic.com/images?q=tbn:21SLW7C9NsXXdM:http://ecx.images-amazon.com/images/I/518Frco3KaL._SL500_AA300_.jpg
Check Valve:
http://t3.gstatic.com/images?q=tbn:xIVfmPrrsgzS-M:http://www.plumbersurplus.com/images/prod/1/577733-BCV-1-L.jpg
You can use both if necessary but usually only one is required. The in-line check valve can be closer to the pump.
I will post troubleshooting if the site will accept the steps next post. Currently it says I have exceeded maximum length.
Thanks for choosing FixYa.
Kelly
Aug 16, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a Canon DR-3080C II that the images scanned are totally black. I have tried cleaning it, reinstalling drivers, moving to a different PC, and using different programs & settings with no change. ...
Check the brightness setting. Try keeping at close to the maximum and scan. If it is still black, may be the lighting module or Scan module is affected. Check for any loose connections.
S. Mohan
Oct 21, 2009 | Canon DR 3080C Path-Through Scanner
2001 f 150
Discount tire has a website for different tire sizes and how the sizes affect the speedometer reading. I changed my tires from a 60 to a 65 series and gained about 5% better mileage. Basically my speedo shows 70 and I am doing 74. So I get 4 free miles every 70 miles on the odometer. Too much change will rob you of power.
May 06, 2009 | 2001 Ford F150 Styleside SuperCrew
Oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Jun 14, 2008 | Heating & Cooling
Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Jan 06, 2008 | Samsung AS18A6RB Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
74 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
