Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Ice maker For a few days the ice maker was making too much ice; I had tempty the ice out. Then it completely stopped making ice. Any suggestions on what could be causing this problelm?
  • Anonymous Mar 22, 2014
    ice maker stopped making ice
  • 725 Answers
Check you bail arm .( wire that stops the ice maker) make sure it is hitting the ice when its full. if you can lift it up and it still makes ice then the head is broke and will need to be replaced.
Posted on Jul 08, 2008
106.57029 ice maker intermittent
there is usually an ice overflow switch or electric eye
sensor telling the ice maker that the bin is full. Something
may be obstructing this.
Nov 08, 2013 | Kenmore 57029 Side by Side Refrigerator
Samsung twincooling icemaker leaking water & overfreezing
probably the water valve is not shutting of completly . this will flood the tray and then run over into the bucket. try // i would replace water valve . if this does not correct prob. replace the ice mker head as it time's the fill..
Dec 11, 2009 | Washing Machines
Ice maker stopped working
If you manually advance the ice and when the ejector blade reaches 10 oclock that when it calls for water. You should hear the valve come on. If not it could be a bad water valve. Part#2552A or you might want to doublecheck to see if your getting voltage there when the blade reaches 10 oclock. If no voltage then the water switch is bad.
Jul 19, 2009 | U-Line Icemaker
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Oct 10, 2008 | GE Refrigerators
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
271 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
