Question about Panasonic Televison & Video
Panasonic Plasma TH-50PZ77U automatically shutting off after about 3 minutes. The power button blinks on and off afterwards. I have to unplug the television to reset before I can turn on the television again. Then after about 3 minutes it shuts off again automatically.
  • 3 more comments
  • jjonesd Jun 30, 2008
    It's blinking 6 times, pause then 6 times again repeating. Thanks -Jeremy
    It blinks six times, there is a pause and then it repeats. Thanks, -Jeremy
    Thanks Dan! -Jeremy
    Thanks sweet_rascal, how do I fix it? Do you have a recommendation for a service center in the Seattle area? Or someone I could call for a home visit? -Jeremy
    I appreciate your suggestions. I'd like to click on the accept button but it's not showing up anymore. Maybe if you reply again it will? -Jeremy
  • 983 Answers
I think this is happening due to the over heating of some component inside the TV ...
the component may be capcitors or the transformers ...
just have a check is there any burning smell when you open the TV .....
this may also happen if the grounding is not proper or if the grounding wire is in loose contact inside the TV
Posted on Jun 30, 2008
    Guru:
  • 1,894 Answers
This auto shut off can be due to the some shorting in the power board or can be due to the problem of excess heating in the power board.
if you can please tell us the pattern of the blinks.
  • 4 more comments
  • dewan nafees ahmed Jun 30, 2008
    6 blinks means
    PROBLEM is:
    Driver SOS 1
    (SC energy recovery circuit)
    MALFUNCTIONING PART is :
    SU / SD / SC Boards
    SC Board = Scan Drive
    SD Board = Scan Out (Lower)
    SU Board = Scan Out (Upper)
    The SC board is responsible for the generation of the scan pulses. Scan pulses are used for initialization and
    selection of the pixels.
    The SU and SD boards are de-multiplexer boards that are responsible for converting serial data output of the SC
    board into parallel data to drive the panel.
    6 BLINKS SOS:
    PIN 90 of the MPUIC9003 monitors the status of the SC board.
    During normal operation the transistor Q6581 and IC6581 output a low to pin 90.
    If the SC board becomes defective, a high is provided to pin 90
    As a result, the unit shuts down and the power LED blinks 6 times
    for the service of this i would recommend you to get it done by the Panasonic authorized service center.
    and i am not aware of your area. so cant give a clear location of the service center in your area.
    but my advice is not to go for unauthorized centers.
    thank you
    please dont forget to accept the solution if you are ok with it.
    thank you once again.
  • dewan nafees ahmed Jul 05, 2008
    i am also not sure as where the accept button is present in customers side.
    since we have not been in customers side even once we don't know how this system works on your side sir.
    but if you find a accept button please don't forget to click it. thank you.
  • 4,234 Answers
This unit is going into protection mode because it has detected a problem inside. Can you count the number of blinks please. That should be a repeating count. This will help to isolate the problem circuit.
Thanks,
Dan
  • ABRsvcs Jun 30, 2008
    Thank you for the update. The 6 blinks will indicate the circuit that has the problem. I'll look up your model tonight abnd provide you with details.
    Dan
    Correct info provided by Sweet_Rascal. I would do as suggested in that posting. If you go to the Panasonic website, there is a service center locator that can get you the closest authorized service center for your product based upon your Zip code.
    Dan
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
I have a panasonic plasma tv. Model #
I don't know but I'm having a similar problem. I have a plasma
TH-50PZ77U. It will run for a while and then shuts off. Also, the volume goes up and up and then it shuts off at times. Like I have a ghost here. I had both of my sat. recievers replaced. It seems to get worse over time with shut down. I called panasonic and they had no info and denied this was an issue but I beg to differ from my research here online. It's only a few years and we paid lots of $$$. They gave me a # for service 1 hour away!
Jun 20, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Oven will not bake but everything else works fine
What is the red light blinking? Count the blinks before it pauses and post back here. It'll give me and everyone else a starting point.
Jan 21, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Televison & Video Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
