HELP TO CONNECT MIKOMI AM216 TO VIEWPIA 40"LCD,NO MATTER WHICH ORDER I PUT THE CONNECTING CABLES NOTHING WORKS?
  • 5 Answers
SOURCE: sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Posted on Feb 10, 2009
SOURCE: cannot connect my mikomi AP-3211 webcam
i can help please contact me
Posted on Mar 01, 2009
SOURCE: viewpia lcd
click menu, on station prog go to EDIT. Press blue button twice, then go to rescan prog. (it seems to clear all previous scanned programs and starts again.
Posted on May 20, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
  • 13 Answers
SOURCE: I have had my 40 inch Samsung LCD for
I have come across that problem about 8 times in the past, only solution to your problem is to have the main board replaced.
Posted on Jun 21, 2009
I'm trying to connect my LG 32LC7D Flat screen t.v. to my HP G62 Laptop via the hdmi cable. No matter what settings I choose on the t.v.'s menu, it continues to say "no signal". Nothings...
go graphic properties and change frequency hertz to 60hz or on which its compatible.some lcds not copatiable with greater then 75hz frequency. you have to chang this thing for second disply not main setting for your laptop lcd
Jul 11, 2011 | LG 32LC7D Television
We have a 40" LCD Samsung with HD. It was working
If you are using Component Video for connection, this is an EASY fix. The component video cables were installed in the wrong order. Make sure the cables are connected to the right colors as it is very easy to mistakenly cross the Green and Blue cables. Using a flashlight will help so you can see them easier. Don't forget to check that the cables are in the right order on your accessories, too! Hope this helps.
Dec 19, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My Samsung LE40R73BD 40 in. HDTV-Ready LCD Television does not seem to start correctly, now just tries to turn it self on clicking constantly. What is the answer to resolve this
Are you convinced that all cables are correctly connected, also to the electricity. The scart cable(s) are properly in place.
Try to turn the TV off the next time it shows a mind of its own. Disconnect it from the electricity, turn off any extra units that could be attatched to it. Let the TV rest for ,2-10 minutes suit my appliances well. Then start with cables and connections in reverse order. This has oftrn worked for me I havebecome more patient as the years goby.
Jun 16, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I would like to know how to tune a PS2 into a mikomi portablt tv without loosing any other channel. So I can use my PS2 on channel 6?
Why don't you use the tulp wire to connect on AV3 port.
Yellow= Video Red= the sound cable right and White is the
sound cable left.
You can also use an scart adapter with tulps connection.
When you want to play PSP choose the AV port where you
did connected the the tulp conection.
This will work!
Apr 16, 2009 | RCA Mikomi 5290925 15 in. LCD TV
My tv talks but the picture is not showing
Check your antenne connection or when you use DVB check if
the scart cable is fitted well.
This could be the trouble why you don't see anything and hear
only the sound.
Mar 12, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Cables
HDMI cables are the best you can get right now as long as all your components have HDMI connections. Just don't overpay. Order them online and you'll be able to find them for less than $20 each. Walk into a store and you'll get jacked for $75 or more.
May 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Viewpia lcd
Oct 26, 2007 | Televison & Video
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
