Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
FILLS BUT NO CYCLE
WHEN I PUSH START, IT FILLS THE TUB FOR A MINUTE, BUT NOT CYCCLE AFTER THAT. WHEN I OPEN THE DOOR, I SEE WATER, BUT WHEN I PRESS START AGAIN, IT DRIANS THE WATER.
  • 54 Answers
You need to check for 110 vac at the main motor after the diswasher fills. If you do then replace the motor and if not then you need a computer.
Posted on Jul 04, 2008
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Jun 04, 2010 | LG WM2277H Front Load Washer
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
Jan 03, 2009 | Maytag MAH20PD Front Load Washer
Not enough water in tub
Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
99 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
