Question about Vacuums
We need to replace a hose on a Samsung Quiet Jet 9069G...Where would be the most reasonable place to get that? Maura
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723730
Generic problem for all Vacuums
Posted by marnibird on Jun 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I checked the website and there is a Samsung parts dealer that I will list below for you to contact them to order the parts that you need. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.samsungparts.com/
J & J International, Inc.
311 Route 46 W, Suite E
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 01, 2008
My Dyson DC35 upright handheld shuts of intermittently while I am trying to vacume. It has a full charge. Any suggestions
Hi Maura,
Thank you for reaching out. I am sorry to hear you are having difficulty with your DC35. Generally, the problem you described is caused by a blockage or unwashed filter.
First, we recommend inspecting the cleaner head for any obstructions, then the wand and finally the inlet pipe where the wand connects to the main body. Second, we recommend washing your filter at least once a month by rinsing it with cold water only, squeezing it to remove any excess water and allowing it to air dry fully before returning it to your machine. Finally, if for any reason the steps above do not resolve the run time issue you have encountered please contact our Helpline to speak with an expert.
US - 1-866-693-97666 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 05, 2013 | Dyson DC35 Handheld Vacuum
I have a torn hose on my Samsung Quiet Storm should I try to repair or toss it. Mfg no longer makes replacement hose
The early hose on these was prone to tearing. If you are careful you can shorten it once. Beyond that it will become too short to use on the vac properly. This hose was copied from the original Black and Decker hose and power head kit and was likely upgraded by a flex vinyl molded hose which should be more resistant to tearing.
Some vac shops carry hose "refills" and a Samsung dealer may have one in stock even if the hose was discontinued. The vac is good quality in its general design and worth fixing although the original diameter of this hose may be tough to match
Oct 30, 2009 | Samsung Quiet Storm 9069 Vacuum
The on/off switch on my kirby g-3 vacumn needs to be replaced I would like to know the best procedure.
Get the parts ... locally or at some place like Repairclinic.com then set aside a Saturday afternoon in a quiet place with screw driver, pliers and a box of band aids and go to it.
Repairclinic.com will also provide you with details of the actual procedure at hand.
That is what I think
a
Oct 05, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Hose has a break
Don't cut the hoser. It has electrical wiring. You will need to replace it. Unfortunately, Samsung doesn't make vac's anyore. you might find a repair place that can fix your hose, or can order a new one. . we can fix it here, we are in Albuquerque, NM. I hope this helps.
Jun 05, 2009 | Samsung Quiet Storm 9048R Bagged Canister...
Not dispersing water all I need is a manual.
I had the same prob. If you have water/soap solution at the upholstery handle, and no water/soap at the front jets, then the jets are clogged. remove the water tank, and you'll see the 2 jets (mine are red) at the front of the machine. Carefully release thw jets by squeezing the 2 tabs on top and lift out. Remove the hose that goes to the jet and clean out the jet (I used a toothpick) and rinse well. I also flushed out the system (hoses) by leaving off the jets and replacing the tanks (water and soap) I filled the soap tank with water too. Then I turned on the machine and let it run for a few minutes (I taped open the lever on the handle) to make it easy on me. Then replace the jets where you took them out, and all should be fine now. I suggest that when your finished using you machine to do your carpets, rinse out the lines with water in both tanks, to prevent soap from drying in the hoses.
Apr 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Not so quiet anymore
If the filters was very dirty, you might have got some dirt in to the motor, best to have it checked
Dec 17, 2017 | Bissell Upright Vacuum - The Pet Hair...
Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Nov 14, 2008 | Samsung 5528R Vacuum
Beam Serenity Plus doesn't ****
there is definately a clog somewhere
run a snake thru your pipes and dont for get the exhaust
Aug 28, 2008 | Beam Industries 2775 Serenity Plus Central...
Samsung jet propel 1800w power clean vacuum not sucking in/picking up on main front edge roller whilst the hose / attachment does have plenty of suction when taken out of its dock
Just had the same problem. Turns out to be the belt that spins the brushes...
Check to see if the brushes are spinning, if not, undo the four screws on the plate over the brushes and the belt is easy to get at. Replacement should be available in any spares store.
Jul 05, 2008 | Samsung Vacuums
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
