Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine want wash
Keeps flashing E 35 see users guide
  • 5 more comments
  • nemo8449 Jun 30, 2008
    do i need to drain it if so how do i drain it and what cretes this problem
    were is the presure sensor how easy is it to repace how much would it be. where is the inlet valve how do i fix that
    i unpluged it over night its still not working
    sorry its flashing E 30 see user guide .\not E 35/
    THE INDICATORS FLASHING E30 NOT E35 IVE TRIED UNPLUGING IT OVER NIGHT WHATS CAUSING THE PROBLEM AND HOW DO IFIX IT
    WOULD THIS COST MUCH MONEY IF I CALLED OUT AN ENGINEER. AND THIS HAS HAPPEND BEFOR THEN IT STARTED WORKING AGAIN. FOR AT LEAST 2 MONTHS.
  • Anonymous Mar 26, 2014
    How do I use this washing machine as I don't have a user guide
  • 4,472 Answers
Sounds like a faulty motor you will likely want to have it serviced.
Thanks,
Lee
Posted on Jun 30, 2008
    Genius:
  • 1,665 Answers
Http://www.howtomendit.com/answers.php?id=6116
E30 means no motor action, suggest you check the motor brushes, checkout the hotpoint web site, www.hotpoint.co.uk then click on after sale service it gives lists of fault codes etc.
    Sergeant:
    Champion:
  • 230 Answers
This problem may be wiht the inlet valve or the sensor that senses the pressure may have the fault so check that..........first of all check the valve
    Guru:
  • 1,342 Answers
Are you sure it is E30 and not F30?
Here is a list of Hotpoint Error Codes
Seems to be a motor problem.
    Genius:
  • 1,142 Answers
That's the correct part indicated by Sweet_rascal
E35 Pressure sensor indicates water overfill.
  • 405 Answers
Good Day,
E30 means the motor isn't working on this machine. There used to be a 7.5 amp fuse on the power modules on these micro processor controlled washing machines which used to blow if the motor went faulty.
It could be that the brushes have worn out and the motor has blown the fuse. This can happen if they spark excessively but it can also happen if the armature goes down to earth, or the armature is faulty. You really need to test the insulation of the motor though with a specialist meter (megger)
Good Luck & hope this helps
    Master:
  • 638 Answers
Try a simple procedure of hard reset.
1)unplug ur unit from power port.
2)leave it unplugged for a hour
3)replug in and on ur unit.
above procedure will reset the settings n solve ur problem.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 1 more comment
  • hemant somaiya
    hemant somaiya Jun 30, 2008
    i will give u the link to the site with diagrams which will help u solve ur problem with step by step instructions.
    www.repairclinic.com
    after opening the link -click repair help option n then ur model number.
  • hemant somaiya
    link i provided will help u for all the errors.
  • hemant somaiya
    hemant somaiya Jul 01, 2008
    any updates
    Guru:
  • 1,894 Answers
Please do a hard reset by leaving the unit plugged off from power for few hours
  • 2 more comments
  • dewan nafees ahmed Jun 30, 2008
    the water is over filling.
    there is nothing to drain it.
    this can be the failure or any one the two parts.
    one is the pressure sensor.
    other is the inlet valve
    this would cost you some.
    100$ for the service charge and the part cost will be below 100$ sir.
    this is not a big problem. but it keeps repeating fro many customers.
    dont forget to accept MY solution if you go by it.
    thank you
    code e30 means motor fault. this can be just
    • motor brushes,
    • tacho fault
    • module fault.
    can't narrow it down more than this - you will have to
    dive in and check
    Error 30 (on Hotpoint) just means the motor isn't working. Several
    things, including the power module, can cause this. The most common
    cause though is worn carbon brushes. There is also a 7.5 amp fuse on or
    near the power module, which can blow. This fuse is on the motor
    circuit to protect the circuitry of the power module. If it blows, then
    the motor won't work and you will get error 30.
    help for fitting carbon brushes.
    please dont forget to accept the solution
    Genius:
  • 1,447 Answers
Hi-
The error pertains to a main board problem, the only troubleshooting step recommended is hard reset- turn it off and unplug then after a few hours turn it back on- if you are getting the same error still- my suggestion is for you to call your manufacturer. Best i got! Thanks for using Fixya!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 30, 2008
    for E-30
    E30/31:
    Motor problem - check motor brushes, drive belt, tachometer or
    tachometer magnet, motor relay or PCB (TRIAC motor control).
    I suggest you buy the parts first and but the washing machine service manual. so that you will know what to do if an error pops up on your the LCD of your machine CHECK this link, click HERE
Maytag Neptune washer , when I turn it on for a 35 min wash , it works for about 12 min , then tunes off , with a lc on it , ? it just sets there and does nothing ,
"lc" may mean "load capacity" meaning too much weight in the drum. Wash time may be variable, and the load amount too! Experiment with you "wash time" feature, it may be for lighter loads ONLY. Get a user guide for your machine would be my call.....
Apr 05, 2015 | Maytag Neptune MAH5500B Front Load Washer
Hoover performa 900 model number washing machine user guide
Check out this site and see if you can find your model number of your machine.....http://www.whitegoodshelp.co.uk/washing-machine-instruction-books-and-user-manuals/
Aug 25, 2014 | Washing Machines
Indesit washing machine model IWD 7145S says F06 on display and all lights are flashing. its at the end of wash and door wont open
Hi Sammi,
Have a look in the troubleshooting guide of the User Manual Should find some information to help you there. Good Luck,
Jack:}
Nov 17, 2012 | Indesit Washing Machines
User's Guide HOOVER HNWL 7146 Nextra 6 Washer Dryer
Hi if you give me your email address I will send you a nextra 6 user guide
Dec 01, 2011 | Washing Machines
Plz help me i need venus automatic washing machine user manual
did you try manuals online heres is a pdf of it for you hope this helps
www.user-guides.co.uk or here is another site u can try
www.user-guides.co.uk/.../venus/venusautomatic/venus-automatic-washing-machine-user-manual.html
Jul 05, 2010 | Washing Machines
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine
Sure you can. Click on "Indesit" or "washing machines" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 04, 2008 | Washing Machines
Washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
107 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
