Question about GE JKP45 Electric Double Oven
General Electric JKP45 Double Oven
My bottom oven when using the self clean feature continues to run indefiniently. The door lock lights blinks and then it eventually locks and starts the cleaning feature. After it is done it won't stop. I've had it run for more than 6 hours. I eventually for to turn the circuit breaker off until it stops. I call for a repairman but the full Model number does not appear on the side panel. I've only been able to get the full ID number because it has worn off. I think the No. is JKP45WOV1WW???? Unfortunetly the repair man said that he cannot or the door lociking mechanism with out the model number. Can anyone help? Any suggestions on how to better raise the ID. no. that has mostly worn off?
  • 54 Answers
Don't know why repairman couldn't order parts you have your model #. The model # is the JKP45WV1WW, The part # is WB26K5030 for the lock motor.
Posted on Jul 03, 2008
Solution: The door lock needed to be replaced. But without being able to read the model number on the side of the oven, I would not be able to order parts. I tried everything to make the writing stand out more but could not. I eventually found the manual that came with the wall oven. It would be nice to find a medium that fills in the etched in model no. to be able to read it better.
Posted on Jul 02, 2008
I am not able to get the cleaning in my self clean oven to start
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 24, 2010 | GE JKP45 Electric Double Oven
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
GE TrueTemp JKP45 double oven will not self clean / lock
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 04, 2009 | GE JKP45 Electric Double Oven
GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Jan 02, 2009 | GE Profile JT952 Electric Double Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
May 31, 2007 | Frigidaire GLEB30T9D Electric Double Oven
GE JKP45 Electric Double Oven Logo
397 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
