Question about Zebra Z4Mplus Label Printer
Stops printing after sending job
I have a Zebra Z4Mplus that stops printing mid-label and then pauses.When I press pause to continue printing, it stops again and again. Any thoughts?
  • ncooper359 Mar 20, 2009
    Found out that the sensor was dirty and wasn't sensing the labels properly.
  • Michael Olavere May 11, 2010
    what software are you using? bcoz there is an option pause printing after batch uncheck it
    Champion:
  • Zebra Expert
  • 285 Answers
Try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
Posted on Nov 13, 2010
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
Feb 21, 2015 | Zebra Z4Mplus Label Printer
Z4Mplus test page
Do you want to print out settings? Do you want to print a printhead check? Make sure supplies are loaded and the printer is ready to print. Turn off the printer, press X button, turn on the printer while pressing de X button and release the button after aprox 5 seconds from power on. This will print out the configuration page. Do the same but with the Pause button, and you will get a printhead quality test. Note that the test with Pause button it will stop automaticly only after some 10 printed labels . You will need to restart the printer after that, or press the cancel button several times.
May 06, 2014 | Zebra Z4Mplus Label Printer
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
My Zebra Z4m plus start to print in middle of the label,but suddenly to appear next message. error de papel.and stop the machine and the print on the label is in wrong positions
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS.
Roberto Martinez
Sep 28, 2009 | Zebra Z4Mplus Label Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Delay between labels
download the manual from zebras website im sure its not that complex to adjust it. www.zebra.com
Aug 16, 2017 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
551 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
