Question about HP Compaq Presario V6000T Notebook
Scrambled keyboard All the keyboard keys are scrambled--typing the wrong key/function. Nothing was spilled on it, and I have restored it back a few days. It was working fine, and then the next time I tried to use it, everything was scrambled. It doesn't matter if I reboot, etc. only a couple of keys on my laptop give the wrong letters when used. Can you give me a solution for this
  • HP Master
  • 4,338 Answers
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Posted on Sep 30, 2008
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
My keyboard is not showing in device manager
To install your keyboard or mouse:
  1. Exit Windows and turn off your computer.
  2. Unplug the power cord and modem and network cables.
  3. Disconnect the old keyboard or mouse.
    If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
      If you are installing a PS/2 keyboard, connect the keyboard to the PS/2 keyboard port on the back of your computer.
      1. Connect the power cord and modem and network cables.
      2. Turn on your computer.
        To install the device driver from the Gateway System Restoration Kit:
          1. Start your computer. The Add New Hardware Wizard window opens.
          2. Click Search for the best driver for your device, then click Next. Complete the wizard by repeatedly clicking Next until the wizard tells you that it was unable to detect any devices and that it has installed an unknown device.
          3. Insert Disc 1 of the Gateway System Restoration Kit into the CD or DVD drive. The System Restoration Kit program starts. Go to Step 6.
            - OR -
            If the program does not run automatically, go to the next step.
          1. Click Start, then click Run. The Run dialog box opens.
          2. In the Open text box, type d:\autorun.exe (where d is the drive letter of the CD or DVD drive), then click OK. The System Restoration Kit program starts.
          3. Click the Install Hardware tab.
          4. Click the device driver, then follow the on-screen instructions. Installation is complete. If your keyboard or mouse does not function correctly, see "Troubleshooting".
        1. The keyboard does not work
          bdgreen2.jpgMake sure that the keyboard cable is plugged in correctly.bdgreen2.jpgRemove all extension cables and switchboxesbdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgClean the keyboard by using an aerosol can of air with a narrow, straw-like extension to remove dust and lint trapped under the keys.bdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgReinstall the keyboard device driver. For more information, see Installing the device driver.
          A keyboard character keeps repeating
          bdgreen2.jpgMake sure that nothing is resting on the keyboard.bdgreen2.jpgMake sure that a key is not stuck. Press each key to loosen a key that might be stuck, then restart your computer.
          Liquid spilled in the keyboard
          bdgreen2.jpgIf you spill liquid on the keyboard, turn off your computer and turn the keyboard upside down. Let the liquid drain, then let the keyboard dry before trying to use it again. If the keyboard does not work after it dries, you may need to replace it.
Jun 30, 2012 | Gateway 7001433 Keyboard
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
The keys do not work. My 2 year old spilled coffee on my laptop. Some keys worked but most on the left side keys didn't. I tried to clean the keys with a cotton swab and alcohol. Now none of the...
Best solution now is to find a replacement keyboard. They are very easy to replace. Also, could use an external keyboard. Not ideal but it works.
As for cleaning, if the coffee had sugar and cream there is not much you can do.
There is one option I hesitate to suggest. Take the keyboard off, run it under warm water and let it dry for a few days before putting it back. May or may not work.
May 25, 2011 | Toshiba Computers & Internet
A few keys on my Acer 4420 are not working properly and I have no idea as to why. The keys are my o, p, l, ' and period keys. When I do use them they type out random characters. My o keys types out i75`,...
If a neighbor will let you,disconnect their keyboard and try it on yours.If it works normal,the problem is the keyboard.They are fairly cheap to buy brand new.If it does not go away,something is wrong,most likely the IC which interprets the keyboard signal and converts it to letters.It sounds most likely to be the keyboard because it is a few characters consistently.Perhaps something was spilled in that section as they are quite close together.Good luck,Greg
Oct 30, 2010 | Acer NSK8458AN Keyboard
Some keys of my keyboard doesnt work..(5,6,r,t,f,g,v)..
If they type something else instead then you need to hit the scroll lock key to release the keys. If nothing comes from typing the keys then you need a new keyboard. Best source is EBay if it is a laptop.
Feb 21, 2010 | Acer NSK8458AN Keyboard
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Scrambled keyboard
y dont you try to connect the keyboard to another computer and check out whether there is any problem with the keyboard also... after this u will know whether it is a problem with the keyboard or not...
Feb 08, 2009 | Sony VAIO VGC-LS30E Desktop PC
Keypad not functioning properly...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
May 14, 2008 | Acer Computers & Internet
Scrambled keyboard
Have you tried cleaning and reseating the zif connector that connects the keyboard to the motherboard? Depending on how many cats and kids bang on the laptop, that can cause a problem. Another possibility is using an external keyboard and see if the same thing happens. If so, look to see if a keyboard program of some sort is running. If the external keyboard works fine, then you will need to replace the internal one, or just continue using the external one.
Oct 28, 2007 | Compaq 310640-001 Keyboard for Presario...
HP Compaq Presario V6000T Notebook Logo
574 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
