Question about Whirlpool GEW9250 Electric Dryer
DIM LIGHTS ON CONTOL PANEL
I HAVE ABOUT A 2-3 YEAR OLD WHIRLPOOL DRYER... CAME HOME FROM VACATION TRYING TO START THE DRYER , AND THE DISPLAY PANEL LIGHTS ARE VERY DIM, IS SET TO THE HEAVY SETTING AND WILL NOT TURN ON. WHEN YOU OPEN THE DOOR THE LIGHTS ARE ON.
I UNPLUGGED THE UNIT OVER NIGHT AND PLUGGED BACK INTO HAVING THE SAME ISSUE! HELP!
  • 1 more comment
  • mccmikesandy Aug 03, 2008
    same problem with dim dryer time display,
    left number bright, right number dim and even flickers and goes out.
    When left number is out, dryer won't work
    slap side and dryer works. Sapping harder every time to get number to show. I know it will only be a matter of time.
  • j_linan Aug 04, 2008
    Have the same problem. I replaced the control modual and this seemed to fix the issue. After the dryer was plugged in for a day the issue came back.
  • Ryan Carrier May 11, 2010
    What is the model of the dryer? Sounds like you may have an issue with the control module.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
I had this same problem and read several website with complaints to this issue. people replaced the control panel and or the interface panel. I am an electronic tech. and I found the issue on mine was the ribbon cables from the control board to the interface board had excessive resistance. I unplugged all four ribbon cables from the control board and interface boards and reseated them. My dryer has been working flawless now for 5 months. P.S. alot of people replaced their interface board to fix this issue. I am thinking maybe their problem all along was the cable assembly?
Posted on Oct 24, 2009
I had the same problem dim lights nothing happens when buttons pushed. I went through the trouble sheet that was in the drying and it pointed me to a bad control board. After replacing the control board it work. Awsome huh. Not it did the same thing a few hours later. I was able to unplug and replug and it worked for a bit and stopped again well after a few times of that it stopped all together. I was kinda upset after spending 135 bucks on that. I didnt want to put any more money into this machine. I took the machine apart and checked all the connections and wires. Removed the front panel and took all the ribbon cables off and made sure those were good too, (didnt short out) everthing checked out. For grins i replaced the 30 amp circuit breaker. The voltage was there but maybe its not getting the amps. I put the drying togeter enough to see what it dose. I didnt want to risk the chance of messing up the control board i bought while doing this so i used the OLD ONe. ( board was sitting on the dryer tub not bolted down). Well low and behold it works. I have been testing it for about 3 hours now. turning it off and on. change the setings on the dryer and so far it is still working. Before it would have messed up already.
Posted on Aug 08, 2008
My dryer gets beeping but it wont turn on
are the lights on but DIM? are there any error codes?
Put the unit in Diagnostic mode by pressing the following buttons with in 5 seconds.
More time > Less time > More time > Less time
all lights should come on and 88 displayed on the 2 digit display.
Nov 13, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer
I have a whirlpool duet dryer GEW9250PW1 and the control panel wont come on, I have took out the circuit boards cleaned them with contact cleaner blew out the top and took off the bottom panel and blew it out, after all that it still wont come on unless you unplug it for at least 20 minutes.
Oct 07, 2009 | Dryers
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Drum light works - contol lights don't/can't start dryer.
Either the machine control, or the user interface. Further diagnosis isn't possible. I'd try the machine control first. It's just under the top panel, along the left side.
Feb 06, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
393 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
