Question about Samsung HCM4215W 42" Rear Projection Television
Remote control for HCM4215W HDTV
Can't perform convergence w/o original remote control. where can i purchace one???
You can do this menu with the buttons on tv, or get a remote form the partsstore.com
Posted on Aug 13, 2008
  • Samsung Master
  • 8,617 Answers
Go to this link and leave a email with the model number of your samsung and let them know you need a remote . They will respond quickly and they will be able to get your remote fast.
http://servicemanuals.vstore.ca/
Posted on Jun 30, 2008
Hello, I purchased and installed one
You will need a original remote to make the changes to the multipoint and single crosshatches. Do a google search for remote controls to find the Philips remote.
Jun 04, 2011 | Philips 51PP9100D 51 in. Television
How do I get to the TV convergence menu from the remote control. Model JVC 52V765
You need the original remote in most cases. Also, some models just have a button on the front of the TV.
Sep 12, 2009 | JVC AV-48WP74 48" Rear Projection...
Red convergence can't be adjusted
replace the two STK394-250 Convergence ICs.You can get the original replacement ICs at the following link with free step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/stk394250/cName/convergence-ics
These are the original ICs not the cheap chineses knock offs
Apr 30, 2009 | Mitsubishi WT-42313 42" Rear Projection...
My i art pro is showing doubles.when performing a convergence manually,i noticed that that i can fix the problem by using the remote control.the problem now is that i can only go up and down when...
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 10, 2009 | JVC AV-56WP74 56" Rear Projection...
Converging
in most cases yes u need the original remote
Feb 04, 2009 | Philips 60PP9202 60" Rear Projection...
How do i realine the bulb in my samsung rear projection tv
use you're remote to enter code mute 183 while tv is on then press 7 for red 8 for green and 9 for blue control. arrows or knobbie will move cursor. if you still can not control the red you will need to change the red convergence ic...press perfect focus to save changes if pf is not on remote maybe on tv if neither you will need to get a remote that has it to save info.
Jan 27, 2009 | Samsung HCM4215W 42" Rear Projection...
Adjustments
On the Akai PT429HD? No, you need the original Samsung, as only it has the button to save convergence settings. I got mine for ten bucks. Without doing a proper convergence your set is kind of wasted, so that ten bucks is worth it. I see the price of this remote has spiked lately, so I'd start with ebay first of all.
If you've tried my convergence procedure on the Akai remote and can find a button that saves the settings (the cursor will blink and then center) then you don't need to buy a Samsung one. The only universal remote that has a chance of doing the job would be more expensive than the real one.
Apr 12, 2008 | Akai PTH5498 54" Rear Projection...
Still can't get into the convergence mennu
You may need the original remote. This is normaly needed to access this menu
Jan 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
