Question about HP PSC 2210 All-In-One InkJet Printer
PSC 2200 All 4 lights keep flashing the message is to remove and check cartridge.
All 4 lights keep flashing and the message is to remove and check cartridge. I have cleaned the cartridge connections and everything else I know what to do.
  • Anonymous Jul 27, 2008
    same prob cart ok what now ?
Hey I figured out how to fix this problem. The problem is not the cartridge it is the clamp that holds the cartridge down if you look at the bottoms of the cartridges the offending cartridge is lower. I beleave it is the spring that gets tired in the hold down lever. What I did was put a piece of cardboard behind(above) the black plastic with spring in the lever. What I used was a coaster from the bar and that tightend it up enough and it worked right away.
thanks
Cory
Posted on Dec 24, 2008
No, both cartridges are new and the check cartridges message still persists while the old cartridge does not get this message. Both cartridges were bought at two different stores and a few months apart....
Posted on Jul 31, 2008
  • 61 Answers
First ckeck out your cartages are ok or not if your cartages if ok then replace carrage assy your problem will be solved
Posted on Jul 24, 2008
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
It keep asking me to remove and check cartridge. I have and it keep saying it
There's a help page for trying to resolve the "remove and check cartridge" issue. See next link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042821&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=79499&lang=en
In case you need the PSC 2200 series manual ( in pdf format, readable with Adobe Reader ):
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Aug 03, 2010 | HP PSC 2210 All-In-One InkJet Printer
All the lights keep flashing --won't print!
I removed the black ink cartridge that was REFILLED at a popular retail outfit and replaced it with a remanufactured one I bought on the web. As soon as I closed the lid, the flashing stopped and it has been working GREAT ever since. Many postings had already recommended the changing to a "new cartridge" to remedy this flashing lights and "pen failure."
Jan 14, 2010 | HP Photosmart 2410 All-In-One InkJet...
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
It keep saying clear carrier jam I have cleared everything and pressed the check mark it is not fixed? Help
Problem : An error occurred while communicating with scanning device
After you install a print cartridge, the attention light begins to flash red. The printer will not print. One of the following messages may appear on the control panel:
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Solution :
To solve the problems related to Cartridge Errors we can do the following 4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reseat the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat reseating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step 1: Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE : you can also check the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
final Step 4) CONTACT TO Product Support
Jan 04, 2010 | Dell Office Equipment & Supplies
Hp PSC 950 gives me a message to remove and check black cartridge
Did you remove the tape from the contacts of the new black cartridge? If so once the new one is in, unplug the printer from power and power it back on, it should do a full check after a power on off.
Sep 23, 2009 | HP PSC 950 All-In-One InkJet Printer
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
I have the same problem with message " remove and check cartridge
Make sure the cartridge is in all the way. Did you remove the tape on the cartridge. then shut off printer and turn back on again
Aug 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Flashing lights remove and check cartridges
Try this... At the top are instructions for replacing the cartridges. Farther down are instructions for what to do if you get messages related to your cartridges. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05206&cc=us&lc=en&dlc=en&product=90809
Jun 09, 2009 | HP PSC 2175 All-In-One InkJet Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
HP PSC 2210 All-In-One InkJet Printer Logo
325 people viewed this question
Ben Johnson
