I purchased a lexmark print cartridge from walmart in somerset ky it printed 10 pages and was out of ink the box was stamped it was made in the phillippines the code number is 3464695902 i am very upset because these items are twenty five dollars each and should print more than ten papes any help will be appreciated the item was used in a lexmark printer i own
    President:
  • 1,314 Answers
What was on the 10 pages? If you printed 10 photographs at maximum quality then you may very well be out of ink. If not, then I suggest either going back to walmart or contact lexmark directly.
Posted on Jun 30, 2008
Toner exhasting
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 08, 2011 | Computers & Internet
Tip
How to restore your inkjet printer so it prints just like new!
Inkjet printers all operate the same basic way. There are differences but the basics are the same for any inkjet devices. Eventually a buildup occurs enough that your printer doesn't print. Cleaning cycles use more and since inkjet ink is worth about $8000 a gallon, this is a expensive way to clean something.
So what can we do to clean this just a bit cheaper? We need to find a suitable solvent that will dissolve these deposits without harming the print head. And the one that works great and is dirt cheap is good old household white vinegar. Next we want to get some lint free (preferred but not critical) paper towels. And a clean clear table top to work. You may want to put down some newspaper. This isn't that messy to do but it can get the odd bit of dissolved ink on things.
Now we take the printer and remove the paper and the ink cartridges and set aside. The print head is a small stamp sized thing on the bottom of the cartridge holder. Take about 1/3 of a sheet of paper towel and wet it with vinegar. Next you want to get the wetted towel under the print head. It should fit as this is where the paper goes you print. The towel is a thicker but it is soft. move the print head back and forth over the towel. When the towel is covered with ink, change it and repeat. Keep repeating this until the towel comes clean. It will only take a few minutes. When the towel is clean then you are done. Replace the ink cartridges and paper and you are ready to print.
on Apr 11, 2010 | Computers & Internet
I believe my ink dried out in the holder bracket. I cleaned it with alcohol and replaced the -color and black ink cartridges with new, and can only get a littles ink smeared across the page on the first...
If ink dried out it's done. Recycle it and get new cartridge. If cartridge is more than 50 dollars don't buy it. Go to Walmart and you can by a brand new cannon printer with ink cartridge for $49.00
Jan 11, 2011 | Computers & Internet
My hp 5940 only prints half of each letter on the page
The only serviceable part of this printer is the ink cartridges which includes the print heads. The error is cause by a clogged or defective ink cartridge head. You can retract the cartridges and clean the head with a soft tissue, an 70% alcohol can be of help to loosen the inks. Reinstall the cartridges and test. If error is still there, replace cartridges with new one.
Good luck.
TedMac
Sep 13, 2010 | Computers & Internet
I have a hp officejet 5510 that prints the first line and the next is light and than dark and than light again
The problem could be caused due to blocked printer nozzles or bad print head. Try cleaning the ink nozzles first.
1 Press Setup.
2 Press 5, then press 1.
This selects Tools and then selects Clean Print Cartridge.
A page of patterns is printed. The print cartridges are cleaned. Recycle or
discard the page.
If copy or print quality still seem poor after you clean the print cartridges,
replace the print cartridge that is affected. For information on replacing
print cartridges, see replace the print cartridges.
The link for the user manual can be found at
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Thanks for using fixya
Proton
Apr 18, 2010 | HP Computers & Internet
Greenish tint to black type
This is a dot matrix printer. The way they work is there is a print head that has a heap of little needles with flat tops on them, and they push out at high speed against the ink ribbon, and the ink ribbon is pushed against the paper to make a dot. Then the pin is retracted, spring loaded.
Pretty amazing that it can work that fast, eh!
So the only thing that can influence the ink colour on your paper is the ribbon.
Are you using original Lexmark ribbons? If so, my recommendation would be to take a sample print to where you got the printer from and get them to demonstrate the print quality of one of these printers, then compare it with yours.
Dot Matrix printers will not produce print as black or as high a quality as a laser printer, for example.
Perhaps the ink ribbons you are using have a less than top quality ink in them, and there is a bit of "bleeding" going on - it can only be the ribbon.
Another thing you can experiment with to get the best print quality is the print head gap - there will (should) be an adjustment, and getting that right will make a difference to print quality.
Hope this helps you.
Apr 26, 2009 | Computers & Internet
I have installed two new ink cartridges #80 and #70. When I try to print I get black lines across the page and some blue printing as well as the symbol of a flag shape with colored squares that are...
the cartrudge is not got detected in the printer .as click the properties of the printer go to solution center and then click the options tab and then get the cartridge detected in the printer.and then it will work.
Dec 10, 2008 | Lexmark Computers & Internet
I am trying to use a Z705 color jetprinter, but cannot get it to print from the pc. I can print from notepad (not using the print file from the tool bar but from the notepad file. I have tried everything....
May be you are not installed well the software driver of the printer. First check the test page of the printer.
For test page see the option of the printer icon.right click icon goto the properties and click test page. Then it will not print well after that put the driver cd into the cd drive and install the software.try it and if the prob comes again please inform to fixya.com
May 12, 2008 | Computers & Internet
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
Low ink level after ink refill prohitting print function
Click on your lexmark maintenance tools and click on install new cartridge. This should fix your problem.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
