Question about Frigidaire Kitchen Ranges
Electric bottom oven element, part # 31615900A, for electric range ES340, model # glef379dsd, burnt out this weekend. Bought 4/4/05. See screw from inside oven on each entrance port to rear. How do I remove and install new one.
  • MarcOne Jul 20, 2008
    Very Helpful. Sorry did not get back to you. Away. installed this morning. went like clock work.
    Turned the oven on and no power to either of the elements.
    Tried broil/bake/ etc.
    The top burners are working fine. Only the elements in the oven.
    Any suggestions. Needed to replace the element anyway
  • MarcOne Jul 21, 2008
    Clock is working fine. All other 220 in house is working. Dryer/Pumps(2)
    Do I still need to do above. Speed Bake Fan and Light working in oven. Let me know
  • 5,911 Answers
Just follow this link for step-by-step instructions on how to replace a heating element in an electric oven:
This write up is for MOST electric ranges. It is a simple repair if you follow the steps. If your range configuration is different from what I have provided to you, please let me know. I hope this helps you.
Posted on Jun 30, 2008
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Jul 03, 2008
    Did my advice help you with replacing your oven heating element?
  • Jeff Rockwell
    Jeff Rockwell Jul 21, 2008 the clock assembly working? This is what controls all of your oven features. That's why the surface elements may be working, but the oven is not. The surface elements work through individual infinite switches which are located behind each control knob. Have you checked your primary power? If not, turn off the main breaker and carefully slide the range out so you can get behind it. Remove the small access panel where the power cord attaches to the terminal block. Attach meter leads to the RED and BLACK wires and turn the breaker back on. You should be reading 220-240VAC. If not, you may a primary power problem. I could not find a wiring diagram for your range online. There should be one inside the control panel or on the back of the range. If you are missing one leg of the 220 circuit, some features of the stove may still work, while others don't. I need to know what this reading is as the terminal block.
  • Jeff Rockwell
    The 220 circuits in the rest of your home may be ok, but if you have a problem with the receptacle that the range plugs into, you could still have a range that isn't working properly. You need to make sure the proper voltage is coming from the receptacle in order to determine if you have a power related problem, or a problem with the Electronic Oven Control (EOC) not turning the elements on properly.
My stove self cleaning light keep blinking and it will not bake. I have tried unpluging it from the wall.
check the bake element it most likley burnt out ..unplug range ..remove oven racks ..look at element with flash light to see if it broken burnt..if it is ..remove the 2 screws at the hing ..pull element out ..remove wires will need model#an serial # to purchase call local appliance store for element ..or the local used appliance repair shop may have one cheap..let me know ..good luck/joe/
Aug 27, 2010 | Frigidaire FEF352 Electric Kitchen Range
Designer series model 484440A Tappan electric range: oven element burnt out. Can't get the old one out!! Help mary
There should be 2 screws that hold the element in place. If you are having trouble getting the screws out, DISCONNECT POWER, then take a flathead screwdriver and shove it between the element bracket and the oven wall. Apply a twistnig force to the screwdriver as you unscrew the screws.
Mar 29, 2010 | Kitchen Ranges
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
Pilot light is out but can't figure out where it's located in order to relight it. model is Frigidaire ES340
Aug 11, 2009 | Frigidaire Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Dec 28, 2008 | Kitchen Ranges
Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Feb 09, 2008 | Kitchen Ranges
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
391 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
