Question about Kenmore Heating & Cooling
Plug trips and cuts off power supply - Kenmore Heating & Cooling
  • Don Berry May 11, 2010
    This is simply not enough information to make any diagnosis. Please provide your make, Model, Serial number and let us know what things you have already tried. Thanks.
As my air conditioner is under warranty, a technician is coming to my home tomorrow. Thanks.
Posted on Jul 01, 2008
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
What caused my bosch matter saw to quit cutting in middle of the cut
Several possibles:
1) Load exceeded circuit amps. Breaker tripped.
2) Load exceeded saw amps. Reset tripped.
3) Wiring failure in saw.
4) Wiring failure in supply.
Time to start checking.
Note- if the blade is dull or the load on the saw is too great it will trip one of the breakers.
Mar 26, 2016 | Bosch Saws
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Electrical trip switch
Buy a UPS "uninterruptable power supply" from a office supply store. Plug your pump into the UPS. When the power stops, pump will continue to run.
Jan 15, 2014 | Deluxe Car Seat Piddlepad Prevents Stains...
My dad is trying to fix his 1991 ford explorer and said it ws the fuel pump but then it didnt turn on so then they told him it was the duralast/relay-fuel pump .. but how do you install that?
the fuel pump relay is under the hood, I can't tell you for sure which relay it is I usually look at a wiring diagram and match it by wire colors. It could also be the inertia fuel cut off switch which is a safety device to cut the fuel pump off in a rollover accident. I've seen people accidentally kick these which will trip them or even kick the plug loose which cuts power to the pump. they are usually located in the center front under the dash or behind one of the kick panels on the side of the floorboard. if it's tripped the button will be popped up just push it back in and it will reconnect the power supply. it's also possible the relay under the hood got water in it and fried but it's hard to say for sure.
Dec 24, 2010 | 1991 Ford Explorer
UPS does not supply power to equipment after power trip
Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
Apr 20, 2009 | Computers & Internet
32" visio tv tripping power throughout the house
I would have an electrician check to see if you have a grounding issue. Especially at the outlet that you have the power strip supply plugged in, Check to see what kind of your circuit panel is going to trip for electrical arc or electrical short. Newer panels should have both. Older just for electrical short. Have your electrician make sure your wiring is entirely copper, if it isn't and it's aluminum. Have him make sure the outlets are aluminum rated, and not designed for copper. Defintely check grounding. Good Luck
Oct 27, 2008 | Vizio L32 32 in. LCD HDTV
Air conditioner breaker on plug keeps tripping
The instruction manual says:
If the safety device incorporated in the plug trips and cuts off the power supply, check that the power cable and plug are not damaged. If the power cable is undamaged, to restore operation press the RESET button.   To verify the correct operation of the plug, press the TEST button periodically and make sure the appliance disconnects.  If this is not the case, contact the service center. To restore operation, press the RESET button.
Customer Service: 800-322-3848  US Customer Service: 888-335-6644  Canada
Hope this helps!
Jun 08, 2008 | GE Heating & Cooling
GFI outlet fuse trips even when nothing is plugged in
hi there, there is a shorted electronic parts at your power supply, fuse allways blows means a shorted diode, regulator and a transistor. it should be replace, do some testing and replace the defective parts. ty
Jan 10, 2008 | Computers & Internet
Heating & Cooling Logo
32 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
