Question about HP PSC 1410 All-In-One InkJet Printer
Error offline - HP PSC 1410 All-In-One InkJet Printer
    Novelist:
  • 169 Answers
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Posted on Feb 04, 2011
SOURCE:
Why is it a error code on my screen saying something went wrong the error code is E2030000080C87AF000D
Use the Offline System Update Diagnostic Tool on your Xbox One to troubleshoot your error. You'll need to use a flash drive that's converted to NTFS.
How to use the Offline System Update Diagnostic Tool on Xbox One
If going through this process doesn't work, you'll need to reset your Xbox to its default factory settings. Do this by hitting the "Restore Factory Defaults" in Step 2 of the Offline Diagnostic Tool.
If that doesn't work, you'll need to send in your console to be repaired.
May 17, 2016 | Microsoft Xbox One
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
I have a Canon MX310 we are getting the error printer offline, we have repluged in our cables, tried new cables, rebooted the computer, and turn the printer on and off
Error: Printer is offline
Solution: Set printer from Offline to online
For Windows 7, open Devices and Printers
Right click on the Printer icon and click on See what's printing
Click on Printer to open the drop-down menu.
Click on Use Printer Offline to remove the check mark and allow use online.
For other Windows operating systems, see here.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
"The printer is offline. Check that
Issues or errors within the operating system might also cause printer offline issue. Users having offline printer issue are advised to clean the registry of the system, check integrity of the system files and also remove any malware infections using an updated antivirus program. Users must also stop the printer service active on the system and restart it as the issue might be because of errors. Removing the errors from the system would get the printer working without issues.
Jan 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My canon mp620 is offline. My at&t modem is working and my computer is online - my computer detects the printer but is offline
The users who are experiencing offline errors while using the Canon printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your canon printer.
Jan 12, 2011 | Canon Office Equipment & Supplies
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Machine error 78 offline
You have a bad FUSER. There's nothing you can do. A dealer must replace the fuser.
Jun 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
HP PSC 1410 All-In-One InkJet Printer Logo
205 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
