Question about Toshiba Satellite A135-S4527 Notebook
My keys r locked up and my mouse will not work
    Genius:
  • 2,028 Answers
This is generally a driver issue. You will need to connect to another keyboard and possibly mouse, then uninstall the drivers for the keyboard and mouse (usually called the synaptic pointing device) on the laptop from the device manager, then disconnect the external keyboard and mouse, then reboot. It will find the hard ware and reinstall the drivers. If the problem persists, then it's a hardware issue. Check the connections for the keyboard and mouse, if the connections are good the the devices may have failed and you will need to take it in to have them checked or replaced.
Posted on Jun 30, 2008
Hi, my mom just got a IBM thinkpad. It worked just fine then the other day she told me the keyboard and mouse didn't work.I know somewhat about computers and tryed to fix this problem.I plugged in a mouse...
Check if you have any button on panel says about to lock the keys and mouse? Use your manual book if you have one. Lenovo has got this buttons that locks the keys and mouse to prevent unautorized use while you are away. Possible located next to the audio or power button.
jmc
Aug 18, 2009 | IBM THINKPAD X200 TABLET SL9400 2GB 160GB...
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
During reinstall of XP on Dell Dimension 9100, half way through process the mouse/keyboard locks up and cannot continue with install. Any suggestions? Thanks.
Try using an optical mouse of the latest technology and maybe try a USB key board. Maybe this will make some difference.Try to use the most popular ones for starters...............sodeep
Apr 18, 2009 | Dell Dimension 9100 PC Desktop
KEYBOARD NUMBERS
There should be a button called "numlock" which will enable to you use the keypad to the right of the keyboard, however, you don't need to "lock" the keyboard to use the numbers on the top row.
Apr 15, 2009 | Dell 0Y3740 Keyboard
The mouse pad is locked. it works when the pc is started up. after the desktop loads , the mouse goes into lock mode.
Hello. For laptops there are several key combinations, FN+F1, F2 One of them disables/enables the mouse pad. Good luck!
Apr 15, 2009 | Computers & Internet
Mouse
Try this, If you have an external mouse port, attach another mouse, reboot laptop. If mouse works, depends on operating system? Goto control panel, mouse icon and see if you might have diabled or changed mouse key to use the right key?
Apr 11, 2008 | Computers & Internet
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
