How do I remove it for cleaning...where is the air filter, how to remove, how to clean/replace? .....thanks
grebs430
Locate the cabin air filter container on your Lincoln LS. Looking at the engine from the front, you will find the casing on the left side against the back firewall. The cabin air filter is mounted vertically and is approximately 6 by 9 inches and about 2 inches deep.
Remove the cowling cover by pushing in the black cover pins and lightly prying the cover off with a screwdriver. Lift the filter out of the container.
Vacuum the inside of the container to remove any dust or debris. Wipe down the inside and outside of the container and lid with a clean damp cloth, then dry it off completely.
Insert the new cabin air filter into the container and check to make sure it is seated properly. Cover the container by putting the lid back on and gently pushing down to make sure the pins click into place.
