Error code f05 appears and will not drain - Washing Machines
  • mamaredhen Jul 03, 2008
    ERROR CODE F-05 APPEARED, WASHER QUIT, CLOTHES CAME OUT HOT AND WET AFTER TURNING IT TO DRAIN AND SPIN. PER WHIRLPOOL CUST.SERV. ADVICE I UNPLUGGED IT FOR 10 MINUTES TO TRY TO RESET IT. NOW CYCLE COMPLETE LIGHT IS ON. I TURNED IT TO WHITEST WHITES PUSHED CONTROL ON AND HOLD TO START AND NOTHING HAPPENED. NO CODE,NO CYCLE TIME DISPLAY, WONT DO ANYTHING....P.S. WHERE CAN I GET A SERVICE MANUAL GHW9150P
  • huldamagg Jul 30, 2008
    Ariston washing machine F-05 error code :( What to do??
  • Washing Mach... Master
  • 19,396 Answers
You find the original solution on this link here
Error code f 05 - FixYa
Posted on Sep 03, 2008
jsrock516
  • 5911 Answers
SOURCE: ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Posted on Jun 12, 2008
barkencoa
  • 3463 Answers
SOURCE: error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
SOURCE: My indesit wixe 127, wont
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Posted on May 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Posted on Jan 31, 2010
  • 3230 Answers
SOURCE: Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Posted on Mar 02, 2010
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
Error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Nov 14, 2011 | Washing Machines
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
Wf 860 error code f05 psi switch jammed on full - machine had not emptied water. Is this faulty switch or blocked pump etc?
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Check for blockage first.
Feb 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
Fit back and test
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it...
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Thankyou.
Jan 13, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Error f05
Thanks.
Jan 04, 2009 | Hotpoint Washing Machines
Jun 12, 2008 | Washing Machines
Washing Machines Logo
950 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
