Amd cpu wont lock into place
Hi, i have a sony laptop, quite old, i am trying to put a new cpu in it, however the cpu will slot in but wont slide along to lock into place. it is an old type socket and doesn't have a locking pin or arm, just slides to lock..any ideas...regards - colin
    Novelist:
  • 148 Answers
U need to upgrade ur mother board also when u upgrade ur processor...
its like all the new processors works on the new motherboard's only...
thanks
Posted on Sep 04, 2009
HP Pavilion d4000 (d4495.se-a) cant find or see the USB ports, have reinstalled XP home, new backupbattery, check with Pd-doctor 3.0 -result test 4 CPU processor test, CPU Number 2 (Apic ID 01H) CPU...
You could easily pick up an aftermarket USB PCI card, which will give you 2-4 USB ports that have their own logic chip. These are quite easy to install and very inexpensive.
Another option would be a front-mounted USB hub, which would attach to the USB header on your mainboard. They come in 3.5" size (to go in a floppy drive slot) or 5.25" for CD/DVD size slots.
Either of these should work fine as long as the rest of the PC is OK. If not, they are pretty much universal, so you could put in your next computer. (if it didn't work).
Jun 30, 2012 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Hi, I am having an issue where upon waking my computer from standby mode (S3), there is no display and fan speeds become irritably loud and fast. I have no choice but to turn off the power from the back of...
Sounds like a procie problem.
Check your processor's heatsink, if it really sits flat on your processsor.
Try to replace with another processor, take note of your socket if that is for the board's requirement.
Put a new heatpste too.
Then tell us the effect.
Thanks for using Fixya!
Dec 16, 2010 | ASUS M4A78T-E Motherboard and AMD Phenom...
Nonfunctioning keyboard M6750 Gateway Laptop
That small retaining clip is what holds tension to the keyboard cable where it fits in the slot on the motherboard.
If you have the type of retaining clip that slides down into the slot to hold the cable in place then what you can do is very carefully put the cable back in the slot, then take the retaining clip and lay it on the cable, then try to slide the clip down into the slot with the cable, this will lock the cable in place.... Note, in this type of connector, the cable sometimes goes above the locking clip. if it does not go too easy, then it may be backwards, flip it over and try it again. When the cable is reseated, cover the connection with electrical tape to hold it fast. If the retaining clip is the flip up lever type, then you will have to try and look at it under a magnifyer and try to slip the ends of the retaining clip back into the sides of the slot where they lock in place. If these repairs cannot be done to where you recover functionality, then the motherboard has to be replaced in order to fix it...that keyboard connector is soldered to the motherboard.
Jan 12, 2010 | Gateway Laptop Keyboard for MX6930,...
Inspiron 1501 cpu upgrade problem
Did you check the AMD site for compatibility? If they are, you could have a bad chip, it could have been mishandled or inserted incorrectly. Visual inspection first for burns, contaminated or bent conductors. Static discharge will kill cpus.
Jul 08, 2009 | Dell InspironTM 1501 Notebook
Video Card Problem
hi. The amd semprom has similar to an intel celeron. These cpu's are not gaming cpu's. The graphics card you are using is now quite old- very few agp graphics cards are made now. I would say that the cpu and gpu may be the problem but it depends what game you are playing. New video cards use pci express slot and new cpu's are dual core and quad core. If you are serious abot games then you could do with a new motherboard- maybe one supporting an intel core 2 duo cpu, to that add at least a Nvidia 9600gt 512mb gddr3 video card and have 3-3 gb's of ram.
May 27, 2009 | ATI RADEON X1650 Graphic Card
Swapped a AMD Athlon MMX for a AMD Athlon XP2800 but get no joy
HI..........
just load a new bios and enable the cpu from the bios window
Nov 15, 2008 | AMD Computers & Internet
Sony Vaio VGN CR-220E
Haha!
I had such dreams too with one of my old Vaio. I really wanted to upgrade the processor and graphic chipset. Turns out that the latter is impossible (it was soldered to the motherboard - it wasn't a graphics card, just an all-in-one chip), as for the processor I was able to take it out but I ran into several problems:
1) vaio added electronic components to the motherboard that made higher CPU speeds unachievable even if the motherboard's cipset (VIA) was able to do that.
2) the cpu maker (AMD in my case) kept telling me that their mobile cpu were custom designed for that specific laptop, so new cpu would be incompatible. Also mobile CPUs are, apparently, only sold to laptop makers, unlike OEMs... (eBay but at ur own risk!).
3) When buying a new CPU, u need to check factors such as the number of pins (mobile cpu are much smaller), voltage, current, wattage and heat dissipation (very important, ur current heat sink was designed for ur current cpu).
But maybe things have changed now. In my case, I could only upgrade the RAM and the hard-drive to larger and faster versions, and the difference was quite significant difference. Faster booting and better internet experience.
May 03, 2008 | Sony VAIO VGN-220E/B Notebook
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Installing an AMD K6-2 processsor on a Compaq laptop
Either your setting is not correct or your new AMD CPU is not a compatible type. One thing very easy to verify is if it is compatible, it will seat very firmly. You may need to check the model and serial number to be sure you get the correct CPU for your old board.
Mar 29, 2007 | AMD K6-2 , 333 MHz Processor
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
