Question about Honeywell Heating & Cooling
I have a programmable thermostat. The LED reads Replace batteries. The face plate has fan switch, a system switch, two arrow keys that are separated by three little function (set, hold, and run). HELP!! How do I remove the cover/face plate to replace the stupid batteries?
    Novelist:
    Champion:
  • 230 Answers
There is a base plate that is screwed to the wall. The face of the thermostat should come off from the base. Usually the batteries can be found back there. Some times a little tug will get it off the wall. Other models have small plastic release clasps that when pushed in will allow the unit to come off.
Posted on Jun 30, 2008
My thermostat isnt kicking on my furnace. even if i use the arrow to increase it, still no heat and it isnt kicking on the furnace. even tried changeing the batteries. sometimes it will say,"return" n
Recheck that the thermostat is wired correctly. If so,switch it to fan on and see if the fan comes on if the fan does not come more then there is definitely an issue with the furnace and not the thermostat.
Feb 15, 2015 | Honeywell RTH221B1000-OB Open Box Basic...
My air conditioner has started changing the mode setting by itself at random times shortly followed by the fan type. Also, it will randomly change from the lowest setting (61 degrees) and shoot all the way...
If this is a system with the thermostat separate from the unit itself, check the batteries. NO batteries, then check the jumped red wire on the thermostat sub-base, which is under the face plate. Gently pry it apart.
Aug 22, 2013 | Haier Heating & Cooling
No heat model 44100b
First make sure that your heating system is on (gas turned on if applicable). Check the unit for any error messages. My furnace has a blinking LED for trouble-shooting. However, the typical issues for it are: blocked air inlet and burner ignite the gas (alternatively, pilot light unlit). Once, the problem has been with the circuit board but that failed in the summer. Make sure the circuit breaker is on and that the cover of the furnace is fully seated. (This can be an issue after changing the filter.)
Next change the batteries if they are low. (This model needs new batteries every 30 days or so since it doesn't use AC power.) Make sure that the thermostat is set for heat. If this is a replacement thermostat, double-check that the wires were connected to the correct spots. (You should have labeled these when the old thermostat was removed.) Tighten all of the terminal screws. Use a unbent paper clip to press the reset button on the thermostat (just below and to the right of the up/down arrows). If the furnace works and the above do not solve the problem, replace the thermostat.
The manual for the 44100b is available here: http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44100.pdf .
I hope this helps.
Oct 20, 2011 | Hunter Fan Company 5/1/1 Programmable...
Switch a rheem thermostat to a hunter thermostat for heat pump
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
May 14, 2009 | Hunter Fan Company 5/1/1 Programmable...
TH8320U1008VisionPro8000 honeywell thermostat with Affinity York
Take a multimeter and check your rh and w terminals. With the face off, you should get 24 volts. If you do not get 24 volts, turn the power off, and check the continuity, you should get ol (open load). Now if you do not have 24 volts, and the meter reads ol, there is a problem in the wiring to the thermostat. My only concern is the green light blinking slowly, but if that is normal on your unit, I will let it be. Hope this helps
Mar 24, 2009 | Honeywell CT3600 7 Day Electronic...
Inaccurate current room temperature reading
It is not adjustable, sounds like the LED is going bad. Tstat has battery back up for power outages. If you slide the fan switch from auto to on does the blower motor start? If not control problem with unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Hunter 44360 problem
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Jul 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
174 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
