Question about Haier hwr10xc6 Air Conditioner
Friedrich air conditioner stopped running. I was trying to find what the air conditioner was causing to vibrate near the unit. I moved the power cord while the air conditioner was running, pushed the wall plug to make sure that it was tight. THe air conditioner stopped running. I am a woman with no mechanical knowledge. My instinct tells me that I might have blown a fuse or short circuited something within the air conditioner.
    Novelist:
    Champion:
  • 230 Answers
This is very possible. Whenever a compressor is unplugged it should rest for about 5 minutes before turning it back on. This is because the refrigerant needs to balance. Otherwise a large amount of amperage may be required to start the compressor as it tries to compress to much refrigerant at one time. I would first check the main breaker for that outlet before jumping to any conclusions. Then let it cool completely before trying again. If this still does not work, you may need to bring it to a service center.
Posted on Jul 03, 2008
Thermostat friedrich twintemp
try unplugging it from wall and try to reset, power outage might have caused a capacitor to fail
Aug 27, 2013 | Friedrich EL25L35 Thru-Wall/Window Air...
I have a frederick x star Its a wall mounted unit and is excessively noisy at the beginning of a cycle or start up it does not appear to be loose in its mounting though why is it making the noise
This often happens when units get a little age on them. But, they quiet down after 30 seconds or so. Be sure the unit is tightly secure in the window, as the vibration my be caused in part by the unit moving slightly in the window.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Friedrich XStar XQ06J10 Air Conditioner
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
Unit wont get cold. motor running fine
heatman101
Jun 08, 2011 | Friedrich QuietMaster RS10J10 Air...
My air conditioner is making a loud noise when I turn it on...even when it is on fan mode. HELP Please!
ir could be the plastic front vibrating, try putting your hand on it and see if you can stop it
May 18, 2011 | Friedrich CP06C10 Wall/Window Air...
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Oct 11, 2007 | Friedrich M18CE Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
