Question about Dometic Rooftop RV Air Conditioner
RV A/C If your unit says it takes R22 is there any other coolant that can be put in the system? I have a pump and can pull the vaccum and I have the gauges to put it in. Thanks for your input.
    Champion:
  • 254 Answers
You can buy a hotshot 410 retrofit kit to replace 22 with 410 if you are looking at an ozone friendly option. These kits can be purchased at Key, Johnstone, or most HVAC suppliers.
Posted on Jul 01, 2008
Where do you install R22 piercing valve on RV ac system?
R22? You're not still using that are you?! On the compressor you have a small tube that goes to the condenser (hot side) and a larger tube that comes back from the evaporator (cold side) The piercing valve goes on the cold side, Fit the guages to the valve. You should have about 3 bar with the unit running
May 10, 2012 | Dometic Rooftop RV Air Conditioner
Where do you recharge the AC with r22?
Most rooftop RV units do not have service ports installed. You would have to get line tap valves to install in the system. The next problem would be getting some R22. Unless you have and EPA CFC certification you cannot buy R22.
Sep 25, 2010 | Coleman Mach III Air Conditioner
Ammonia smell from rv refrigerator. Not working.
i suggest u take ur rv ammonia refrigerator to ur rv dealer for a replace.. ammonia leaking can result in serious injuries, in tight places...
Jul 01, 2010 | Dometic RM2620 Refrigerator
How do u charge the a/c on a rv
this is a sealed system,,,you will need a set of r22 gauges..a piercing valve...an a epa certified tech..if it has r22 ...
Jun 09, 2010 | Dometic Rooftop RV Air Conditioner
I need t recharge the freon. It takes R22. Where do I charge this system? I pulled the roof cap off and cannot find and caps to recharge the system
AC's routinely are sold/installed without charging valves.
So, unless your unit has been worked on/serviced in the past it will not have any place to charge with freon.
Note: unless you've developed a 'leak,' it is unlikely that you've lost any freon, and in the event that you have - it will take a Service Tech to install valves and charge your unit correctly.
I would call a Service Tech to assist.
hope this helps.
Jun 07, 2010 | Dometic Rooftop RV Air Conditioner
Can you use this pump to vaccum r-22 systems the robinair vaccummaster 6cfm
Yes you can,as long as you have fresh oil & it'll pull the system below 500 microns,you shouldn't have a problem.
Jan 09, 2010 | Robinair 6 Cfm 2 Stage Vacuum Pump, R 12/R...
No cold air. Unit runs fine.
yes if it has service ports but if it lee=aked out you need to fix leak first
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Can you tell me what type of refrigerant is in my a/c it is a 15 k btu dometic brisk air roof top unit and is about 4-5 years old.I can't find it on the unit also how much will it hold and if its not 134 a...
USUALLY its R22. DO NOT USE ANY REFRIGERANT TIL YOU KNOW IT NEEDS IT THOUGH. The plate is usually inside the top cover and you can read it after removing the cover. If its a 110or 220 AC unit Im almost sure its R22. And the weight listed will be the most you should try to put in it. BUT before you do that you have to put on a piercing valve. And the pressures are higher for R22 than R134A. It will ofcourse depend on the outdoor and indoor temps as to what pressures youll be running as well as fan speed. Freezing is 57-58psig on R22 so the pressure after ruinnign 10 to 15 minutes has to be greater than 57 or 58 PSIG. It is normal for some units to run for a while at a lower pressure when 1st started though so dont jump the gun.
Mar 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
83 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
