Question about Targa Computers & Internet
Targa Card.....Please Help!
I use a Targa card for photo imaging. It's at work so I don't have the model in front of me but will get it later. All of a sidden copmputer says...Targa Driver Not Available. I took it out, cleaned it up put in a different slot, still nothing. It was working perfectly fine the day before.
    Scholar:
  • 144 Answers
If your PC tells you the driver is not found, the card itself is working but the problem is in the software.
Chances are that a microsoft update caused this problem, specially if you pc is set to automaticly update windows.
Try re-installing the targa drivers, this might help.
Otherwise try to find out if there is a driver-update available on the relevant website of Targa.
Posted on Aug 08, 2008
Can you recover pictures from a corrupted PNY SD 512MB card? If so how?
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is asoftech photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Aug 22, 2011 | PNY 2GB microSD Memory Card
I HAVE HYTECH PCI SOUND CARD. BUT MY FRONT PANEL AUDIO IS NOT WORKING. HOW TO SOLVE
Hello there,
1. You must trace the front panel audio headers if it is attached to the right device.
2. Remove audio headers from the mother board if you are using a PCI sound card.
3. Check if your sound card has the proper audio headers.
4. Next configure your audio software if same jacks are tied up.
The image below is a Typhoon sound card, the rectangle box signifies audio headers. I don't have a clear image of your audio headers. It would be a big help for us to help you. the images provided below will help you to configure your front panel audio. pcsyke_80.jpg
This is the default header assignment for front panel audio.
Most casing this days have this dependent or intact headers unlike before.
This is an example of independent front panel audio in different configurations.
Hopefully this information Helps.
Thank you for using FixYa.
Jul 20, 2011 | Typhoon Anubis Typhoon Silver Crest 3D...
The cable from my FinePix F10 is not transferring photos to laptop. It used to work, and now the message is: "An error is preventing the photo or video from being displayed. Error 0x80010108"....
I'm not sure what it can be, software not properly installed, corrupted, or whatever.
You can get a card reader for a few dollars and use it instead. Easier and faster.
Download the photos and videos to a folder in your laptop. This will not affect the quality or sequence.
After you've downloaded everything, replace the card in your camera and format the card.
Deleting the pictures while connected to the computer may corrupt the card format.
Please remember to format it in your camera.
In one click the card will be empty and ready for more.
Investigate the cause of Error 0x80010108 later, right?
In the meantime you can process the images as usual.
Jun 16, 2011 | Fuji FinePix F10 Digital Camera
I have sony cybershot model DSC-HX5.one fine day i click many photos of my friend party then later when i came home inserted the memory card in my laptop and go to see there are no photos found in the...
Vikram, first of all take no more pictures with the memory card. You'll need to use recovery software to recover your photos. There are very many freeware options for your to choose (here's a short listing with reviews). You'll need to use your computer's card reader with this software. Now AFTER you've recovered your photo's, you'll need to initialize (format) the card in your camera (DON'T use your computer to initialize the card). This will erase the card, but it will also help prevent this instance from reoccurring. Look in your camera's menus for the format option.
Jun 05, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
1. When camera is powered off, lens will not retract. "Whirring" noise heard 2. When camera is powered up the lens will extend. However there is no image seen on the screen when the camera...
Well If the photos you want to retrieve are on the 15Mo of internal memory, there is not much to do here except to see a repair center.
If they are not on the internal memory, open the Battery hatch of your camera, push on the small card that is close to the battery, then take the card out.
Now you can plug this card directly in a card reader.
If you have a laptop you might have a compatible card reader on it, otherwise buy one, it is always usefull.
Retrieving the photo this way on any camera saves battery and is usually faster than when using an USB cable.
Hope this helps
May 18, 2011 | Olympus Stylus 1010 Digital Camera
I'm taking photos with my Samsung D860, and when I want to view the pictures taken, it says 'no image', 'file error' or 'card error'. Sometimes it also says 'card...
Actually the camera is fine and the cause of problem is memory card, Mostly cheaper cards do this but the original cards don't. And as far as concern that you have lost many precious pics, No need to worry about it. Just install any recovery software on your PC and with the help of the software you can get back your pics, Secondly, shift all your pics on memory card in your PC and then format the card through camera, this will solve your problem.(Remember that run recovery software before you format the card if you need to get back your data from memory card)
Thanks
May 13, 2011 | Cameras
When I turn my camera on now it says "no image",A child pushed every button on every menu item I think.Before this happened I had taken about 60 pictures and most of them had the protection lock...
I had success with this:
1. Remove the memory card and then connect the memory card to computer with a card reader, or insert the memory card to card slot if there's any on computer.
2. Download asoftech photo recovery program from
3. In asoftech photo recovery program, scan the memory card and recover your photos.
Apr 04, 2011 | Cameras
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
No executable program in video drivers folder
I have a TARGA TRAVELLER 1574 X2 LAPTOP which is about 2-3 years old. I was using it last week, everything was fine. I put it away, but when i came to use the laptop later on, the screen was completely blank. The power button was lit up and everything else was ok, but no power was going into the monitor. Ive tried to see if it had gone into sleep mode, but to no avail. Ive even tried to reboot with a WINDOWS XP disk but nothing. Do you have a solution to my problem?
Feb 11, 2009 | Targa ProEdit T3K 6221 Graphic Card
Screen reading memory card not initialized
It sounds like your XD card is corrupted. How and why i couldn't tell you. You will need to get the pictures recovered from the card using a special software (image recovery software, can down load for free from some web sites, or some companies can try and do it for you) and then try and format the card in the camera. DO NOT FORMAT THE CARD BEFORE YOU RETRIVE YOUR IMAGES. If you do all traces of the images may be lost.
All the best and happy snapping.
Aug 20, 2008 | Cameras
Computers & Internet Logo
265 people viewed this question
Top Targa Computers & Internet Experts
David Payne
David Payne
Are you a Targa Computer and Internet Expert? Answer questions, earn points and help others
