Blaupunkt typ/tipo is70-33ut.rear projection 68cm tv.( problem-no sound) ,when i touch the volume button, or put pressure on it i get sound
Found a local technican, he fixed the mute.  all done. thanks landcraft.
Posted on Jul 02, 2008
HOW TO FIX A JVC AV-48WP55 248W 48 INCHES BUT NO SOUND......? AT ALL SPEAKERS ARE GOOD
If speakers are not turned off in audio or main menu and not muted and not a box with the sound down---do you hear anything if put ear right to speaker?
Mar 22, 2012 | JVC AV-48WP30 48" Rear Projection...
WT-46809
When you press the Volume Up/Down buttons does it show anything on the screen (like the level indicator bars...)?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Touched a button on remote now no picture or sound Help
do my philips tv has a reste botton model number is 50p8341
May 14, 2010 | Philips 50P8341 50" Rear Projection...
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
The volume will not go up or down
make sure theres batterys in the controll.
try turning it up from the buttons on the tv.
else i dnt no
Feb 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
No sound no picture
have a tech check your tv it needs to be repaired the tv could have some cold solder in the diffrent circuits.if noytthen it will need a complete repair.
Apr 12, 2007 | Philips 51PP9303H Rear Projection...
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
