Question about HP LaserJet 1200 Printer
Paper jam Had paper jam printer picked up about 10 sheets, got jam out. But the yellow light just flashes. Unplugged and plugged back in to no avail
I have the same problem. Blinking Yellow Light. An envelope got stuck and I pulled it out and have tried everything, plug, unplug, unconnect everything, reconnect, put in new printer cartridge, blow out with duster - still all I get is a blinking yellow light. HELP PLEASE!!
Posted on Aug 08, 2008
  • HP Master
  • 2,794 Answers
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Posted on Jun 30, 2008
Suddenly HPJ4580 has stopped printing - when pressing print the first sheet sails through the printer and out the back with no print and the second sheet jams - no matter what I do - changed paper - turned...
I have problems with paper jams all of the time and it won't print once it jams. I turned off the printer, unplugged it, plugged it back in and turned the printer back on and it worked. You could try that.
Jul 17, 2010 | HP OfficeJet J4580 All-In-One Laser...
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Samsung CLP-300 picking up too many pages
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Samsung CLP 300 Laser Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Some paper got jammed, so I took it out. Now the
hi, Hello... I would like to try my hand at your problem (it sounds familiar and might be solvable). In a case like this, one has to treat a persistent paper jam assiduously: 1. Turn off the printer, and unplug it. Open up the printer completely, by all available hatches etc (-being that it's a laser printer, mind that too much exposure to bright light will spoil the bluish-reddish developer drum, so don't let light onto it more than a minute or so... or less preferably.) 2. Examine the path the paper takes, as it is printed, from the beginning (the paper tray, or sheet feeder, or manual feeder) to the end (the output tray), and all points in between. 3. Wherever there are bits of paper, or fluff, or anything like that, get it out of there! (-and of course, don't touch the drum - but you know that aleady.) 4. If there are any mechanical sensor switches, make sure they are not bent out of position or otherwise 'stuck on'... and if there are any optical sensors you can see, be extra sure there is nothing sticking in them (within the squared-off-U-shape most of them look like that), that would activate them. 5. Can't see anything? Reset your printer, as follows: Turn the printer OFF. (Or if it won't turn off, just) Unplug the printer from the wall or power strip. Leave it that way for 10 minutes. Plug it back in. Turn it on if it didn't turn itself on. Wait for it to initialize. Try printing again.
Jun 09, 2009 | Brother HL 2140 Laser Printer
My printer jammed and now it won't start at all
My 1220C printer jammed I got the paper out by pulling and now it won't turn on for printing
Apr 15, 2009 | HP DeskJet 1220c InkJet Printer
Paper jammed. pulled out. now yellow light flashes. runs, but no print
check the paper path, specially where the paper is being pickup. it might still have a small peice of paper stuck in the path. pull out the paper tray. can check the paper path in the front of the printer.
use a flash light if you can not see inside.
unplug it printer after you finished. wait 10 sec and plug it back in. that will clear the printer of any remaining print job, and rest the printer.
if this solve your problem, please rate the answer.
thank you
Oct 14, 2008 | HP DeskJet 5550 InkJet Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
HP 3820 Deskjet Printer
1) take a flash light and inspect the paper path just to make sure there really is nothing there.
2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
3) take out cart. turn off then on, install cart. and do step 2
what happens
Jan 04, 2008 | HP DeskJet 3820 InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP LaserJet 1200 Printer Logo
319 people viewed this question
Ben Johnson
