SOURCE: 1994 chevy suburban silverado horn does not work
there is a 20 amp fuse in the fuse block that feed these circuits
SOURCE: no s.e.s.lamp no spout voltage to tps map all
Remove the radio and make sure he did not cut any wires to the ECM engine control (module).The wires run along the back of the radio to behind the glove box to the ECM.If this is all good then check the connections.If all is good then you could have a bad ECM.Tyr the scan tool on another vehicle to make sure the scan tool is working properly.Hope this helps.Good luck.
SOURCE: HOW HOW TO INSTALL A OUTER TIE ROD A 1994 CHEVY
If your having trouble seperating the tie rod, use a tool called a "tie rod seperater"
