Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Rubber smell, Hoover
When I turn on my Hoover Wind tunnel it smells like rubber, I guess it must be the belt. too tight?, too loose? the smell seems to go away after a few minutes.
  • 2,794 Answers
Its your belt burning up. You have to take the bottom of the unit off to check the belt to see if it was rubbing against something or if it is broken.
Posted on Jun 30, 2008
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
I replaced my belts on my premium hoover wind tunnel and the roller barely moves. Also, I keep getting a rubber burning smell. I'm confused weather if it's worth to have fixed or buy new.
More then likely whats going on with your roller is on each side of the roller is bearings and hair or other things build up and makes it really hard to rotate.Take the roller off the vacuum and check you may be able to clean and oil them.
Jun 22, 2011 | Hoover Premium U45900 WindTunnel Bagged...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover Wind Tunnel has a burning smell when running. I replaced the belt, but this didn't help.
its clogged my vax does that burning smell when it gets clogged up thats for the five minutes before it overheats and stops
Aug 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
675 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
