Question about Dell Latitude D600 Notebook
Problems with my laptop
Every time i try to switch my laptop on in starts flashing the little A padlock at the top of my laptop it does this for so long then switches itself off i carnt even get to the re-boot stage to re boot the system. what do u think is wrong with it?
  • Anonymous Aug 11, 2008
    system will not boot up
    Genius:
  • 2,028 Answers
This may be a hard drive issue. See if you can get into the bios. If so see if it recognizes the hard drive and try to run a hard drive test from there. Then let me know.
Posted on Jun 30, 2008
When my elite book 8530W is switched on 2 padlocks flash on the toolbar the screen is blank & the laptop will not perform any operations at all
It is locked. the password has been entered incorrectly too many times. Contact the manufacturer, prove ownership and they may be able to help.
Feb 24, 2015 | Computers & Internet
My 2004 Chevy suburban won't start but there is a locked padlock on dashboard , is this why?
sound like problem in the theft security systm,try this insert another key in the ignition switch, the other key could be worn where pcm and bcm dont recognize it. and switch ignition on engine off watch padlock symbol with ignition switch left on 10 minutes the padlock symbol will extinguish or turn off then you will turn off ignition switch wait 5 seconds then try starting vechicle if start your theft security failing need let dealership check it out.
Aug 27, 2012 | 2004 Chevrolet Suburban
When I try to turn it on, a padlock icon comes up and says "hold". I cannot get into my mp3 player.
Look for a little tab that shows an arrow or padlock symbol...slide in the opposte direction
Jun 28, 2011 | Audio Players & Recorders
The pen drive indicates write protected and does not allow to write new files.
Three possible sources for this problem, and three separate solutions.
The following procedures assume your flash drive is assigned by MSDOS to drive E:
PROBLEM 1: Pen drive write-protect switch set
SOLUTION: move the tiny switch on the pen drive from the icon of a padlock locked
toward the icon of a padlock unlocked
PROBLEM 2: MSDOS attribute set incorrectly on any/all files on pen drive
HOW TO DISPLAY CURRENT SETTING: START > Run... > cmd
C:\> E:
E:\> attrib /S /D
HOW TO FIX WRITE-PROTECTION PROBLEM: START > Run... > cmd
C:\> E:
E:\> attrib -r /S /D
PROBLEM 3: REGISTRY set incorrectly (targeted by virus or other malware)
HOW TO DISPLAY CURRENT SETTING: START > Run...> cmd
regedit
display HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Control \StorageDevicePolicies
The valid values for this are 0=Disabled (meaning READ/WRITE), and 1=Enabled (READ only)
regedit
set HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\StorageDevicePolicies
to a value of 0 (Disabled)
A fourth way to "Fix" the write-protection problem would be to reFORMAT the flash drive, but
this "solution" merely resets the ATTRIB characteristic of the top-level directory of the
flash drive (while erasing all files on the flash drive), which is done better with the ATTRIB command,
and completely fails to address the possible write-protect switch or Registry issues.
Feb 15, 2011 | Transcend (589307) Media
The battery on my laptop will not come out. The release tab is stuck and no matter what I try it will not budge. Any suggestions?
Run the computer on battery until the battery is dead. Spray the battery bay and release tab with a _LIGHT_ coat of WD-40 and try again. A small screwdriver may help to pry the release out of the way. Too much pressure can break the release. If the battery is working well, you could just live with it in place until replacement time.
Sep 01, 2009 | IBM ThinkPad T40 2373 Notebook
It wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
Dell latitude d505 wont start up. When I press the power button a flashing padlock shows up but the screen never turns on, then the flashing padlock stops, and thats the end.
The flashing padlock should have an "A" in it. That is the caps lock. The flashing caps lock indicates a problem with the memory slot. Try removing memory and replacing. If it continues and you have two modules, take both out and try one at a time. One of your memory modules or slots might have gone bad
Aug 04, 2009 | Dell Axim X50 Pocket PC
Sansa Express mp3 locked. How to unlock n access the mp3 player?
On your Sansa mp3 player there is a little switch that should slide that has an icon of a locked padlock on one end and an open padlock on the other, slide it to the open padlock side and try to power it on.
May 30, 2009 | SanDisk Sansa MP3 Player
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
Dell Latitude D600 Notebook Logo
57 people viewed this question
Alun Cox
