Uniden BC248CLT Base Scanner Logo
A
Anonymous Posted on Dec 12, 2010
How to program channels to Uniden Bearcat 248 ct scanner
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Dec 14, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
933580
Points
7369
Simple yet detailed programming instructions are contained in the factory manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
3helpful
How do you program a Uniden Bearcat bc244CLT?
To program a known frequency into your scanner:
- With power ON, press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program (01 - 30).
- Press MANUAL.
- Enter the frequency, including decimal point (for example, 156.065).
- Press E to enter/store the frequency into memory.
- Press MANUAL to advance to the next channel for programming.
For more information, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC244CLTom.pdf
Bill B
How to program the frequencies on a uniden bearcat 50 channel 800 mhz radio scanner?
To program the majority of non-trunking Bearcat scanners,\:
- Power the scanner ON
- Press MANUAL to stop scanning
- Enter the channel # to program followed by MANUAL (OR just press MANUAL repeatedly to advance to the desired channel).
- Enter the desired frequency, including the decimal point.
- Press E (ENTER)
If these steps don't work with your scanner, please provide your model number and I'll get back to you with specifics.
Bill B
How to program a bc 560xlt bearcat scanner. Thanks, Les. [email protected]
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
5helpful
How to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
2helpful
How to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
59helpful
5answers
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
22helpful
4answers
Programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
16helpful
3answers
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
2helpful
I need to know how to program channels into it
HI again, the 248 is only a 50 channel, do you need this info for the 860? If so, I answered in your other post, but here it is again.
Hi tina33, I have an 860 scanner,and this is how I do it. If there is no freq's in there yet, start on channel 1 and punch in the freq- hit E and it will enter it into the first channel. Hit manual to go to ch 2 and repeat. If you need freq's for your area, go here and search out your state and county and it'll give you a list of freq's for your county.You do not have to add the weather channels as their in there already, just hit the weather button. I use an external antenna on mine as it extends the range and allows me to pick up the cars as well.
If you need a book for your scanner, you can get one here, just print1.gif it out.
http://www.uniden.com/pdf/BC860XLTom.pdf
Hope this helps,, Mechanic
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
