Question about Sony PlayStation Portable (PSP) Console
Won't turn on
My son's PSP will not turn on, the battery has been charged and it will not charge or turn on when plugged in. His cousin has the same problem.
  • 6 more comments
  • wandalk78 Jun 30, 2008
  • jdialloca Jun 30, 2008
    My son's psp won't turn on too : the light turn on and went back off
    No I had the PSP in my posession and he did not break it. He is actually really good with his electonics. Believe me if he broke it , he would tell me, so I could get it fixed.
    It just won't turn on, just stays on the RED light when charging and never turns on.
    Any suggestions???
  • Anonymous Oct 28, 2008
    I HAVE THE SAME PROBLEM
  • panther1fore Nov 18, 2008
    ok i was a watching a vidio from my bed .in acident i droped it .so i said nothing was wong.wen i put the psp together it wont turn on!!! is it the bateery should i buy a new one???
  • fragosoc Nov 18, 2008
    my sons psp wont turn on. the green power light comes on for a few seconds, then turns off. he was playing it just fine. he turned it off went to walmart and bought a new game {Crazy Taxi Fare Wars}. when he tried to play his new game it wont turn on.
  • juniorjimene Jan 02, 2009
    i was just puting music on my psp and then it froze and didnt tern on no more someone help me
  • angelitoserr May 11, 2010
    ask your son if he tried to downgrade his psp.
    If he did there is a chance he messed up and might have bricked the psp.
Iv got the same problem also
i wz upgrading to 5.00 and it turned of,,, then it wont turn on,,it only shows green light
Posted on Nov 05, 2008
Not charging and will not turn on
My son's PSP 2001 had the same problem if it was not in a hard case--the battery wouldn't charge and the PSP would not turn on. All we could figure was that something inside the battery area was loose and the snap-on case held the battery in place better. Try putting the battery in and holding the battery cover on firmly with your hand. If it charges and/or turns on while you're holding it like that, you might want to buy a case to sort of hold it together better. I think they loosen up over time and useage.
Jan 14, 2014 | Sony PSP-2001
I plug in to AC charge for the whole day and try to turnon, with switch on the right hand side, nothing happened
On the occasion it won't chrage the PSP. You should double check that it is charging it. Also, try to see if it'll turn on while plugged in. If it turns on, let it charge, if it doesn't either the battery is shot or the plug-in spot is broken or not responsive.
Sep 12, 2011 | Sony PSP (Piano Black)
I hi have my psp and it dont want to charge i take the battery out and put it in my cousin's psp and it charges in his and when it's fully charges it works in mine..... so its not the battery, i...
You did a good job in isolating the problem. It does seem that your Power charger port is the culprit. I had the same problem with my unit. What I initially did was I applied slight pressure using my finger pushing the adapter plug in the direction of the start button. Apparently, there was a slight gap between connector inside the PSP charger port and the outside part of the adapter plug. Eventually, I added a small layer of solder to one side of the upper part of the charger plug ( near the top part which is colored yellow ). Dont put too much solder, doing so will cause the adapter plug to not fit inside the port. That fixed the problem for me. !!!As a reminder, please do this if you are experienced in using soldering tools !!!!
If your unit is still under warranty, I suggest you let the Sony Technicians fix it for you.
I hope everything works out. All the best to you.
Jul 20, 2011 | Sony PSP-3000 Black Console
Was just wondering I charged my sons psp on the computer but didnt dial down the power so now it wont turn on did i just fry the battery or the whole machine?? thanx S
the computer probably wont supply enough power to charge the PSP, just plug it in to the charger and leave it for 20 minutes and it will power up
Mar 11, 2011 | Sony PlayStation Portable (PSP) Console
PSP won't come on.
yes. the problem here is that adaptors dont convert voltage. so when you put the psp on charge in ireland it must have fried the circuits so that they wouldn't work. this means that the psp is ruined
sorry to be the one to tell you
Apr 21, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim won't charge
maybe the main problem is the unit or the battery itself, go to the sony repairing shop so that they can replace it or fix it. thanks
Mar 29, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp won't charge
check the battery or the charging cable is not inserted correctly or its cutted
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp will not turn on unless the cord is plugged in
ok your son's psp has malfunctioned and instead of trying to charge the batteries it drained them. i would recomend for u to get ur son a new psp and buy a another battery for your daughter.
there is a newer battery being sold that you put AA batteries inside
to make it work. check out your local best buy and wal*mart
Dec 23, 2008 | Sony PlayStation Portable (PSP) Slim...
No power no charge
i think theres somthing is stuck in there chclk if not call sony
Jul 04, 2008 | Sony PlayStation Portable (PSP) Console
Psp won't turn on
Try to charge your PSP with your son's PSP charger and your problem should be solved if so your PSP charger is faulty.
Aug 31, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
196 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
