Question about Whirlpool Washing Machines
Whirlpool AWN 321 washer continues to drain water out of drum throughout the whole wash and rinse cycles. The consequence of this is the machine continually draws in hot and cold water to achieve the programed water levels within the drum. Obviously wash is ineffective as the detergent solution within the drum is continuously diluted. Thanks for any anticipated help. Regards, Mike Wood
  • woodser Jul 01, 2008
    Thanks very much Lumpy816. Feel such a Geek, a simple solution which I really should have tumbled. You have saved me a lot of wasted time and kept the missus happy as well.
    Keep Well!
    Kind Regards,
    Woodser
  • 246 Answers
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Posted on Jul 01, 2008
  • Toby Norton
    Toby Norton Jul 01, 2008
    Glad we could help Woodser. Drop us a note if you have anymore troubles.
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool washer model wslp1100d after the rinse
Hi Derek.
There are several different problems that may result in basket wobbling and machine shaking heavily during the spin cycle. Sometimes the shaking can result in spin cycle not ending, like in your case.
To find out what the problem is the washer must be taken apart and the tub removed.
A common situation is given by a defective drive hub.
At the end of this comment there is a movie showing how to reach and replace the drive hub in whirlpool top load washers. In this washer you will find a more complicate device instead of the hub shown in the movie. There is a pulsator, the balancer and other parts that must be inspected. The two assemblies are indicated respectively as part 52 and 56 in diagram nr.1 below. Here the part list: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470626#d26470626
If you find a foreign object such as a cloth below the tub, then that can be cause for the shaking and wobbling.
If the parts below the tub are OK, then one of the suspensions may be broken. Suspension (damper) is indicated as part 36 in diagram 2. Here parts: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470625#d26470625
Here diagrams:
Diagram 1
Diagram 2
Here the video:
utube.png You-Tube video "aj-HSUOuBBA" placeholder (do not delete) utube.png
Regards.
Ginko
Nov 20, 2011 | Washing Machines
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
