Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi VS-50705 No Video
Need some help with this one. Had this set for around 8 years and no problems until now. Lost video while watching tv, sound and channels change fine. Would like to see if I can repair the problem. I checked the set inside for leaking crts and checked the four fuses and they are good. Need a little help where to go from here. I just ordered a service manual on CD, not sure if this will help but will at least be a good reference I hope. Thanks for any help with this set. Dennis
  • 8 more comments
  • Familycruzer Jul 06, 2008
    Received the service manual. Checked it out but need some expertice. Where should I start to rule out possible problems with no video. Have sound and channels change fine but no picture! Any help out there would be very much appreciated! Thanks, Dennis
  • Familycruzer Jul 17, 2008
    HI Big Irish- Thanks for your help, let me update the latest. Just after my last post on July 6th, I was able to do a service check green light came back 1 then 2. Then the picture would get black broken vertical lines across the screen and the picture would go to a black blank screen. Then this would happen all over again. Two days later tried the set again, now the set is working fine, for now. I know something in the set is breaking down, might be the part you suggest L2C50. The set is normally set up on cable. I thought it may be the box, at first, so I have it going only from the cable line without the cable box. The set was having the problems both ways with just the cable line and with the box added. Now it is working but i'm sure it is only short lived. Not hooked up to any stereo system. Thanks for your help. Dennis
  • Familycruzer Jul 18, 2008
    Hey Big Irish, Checked this morning, did not see any liquid on the boards nor any type of corrosion. Very dusty but did notice on the top area of crts it appears that a clear to yellowish resin/ or hot glue gun type material was used to secure connections. Hardened cob webs of this material is on some wires. Do not think this is what you are talking about. Looks to me like a glue gun was used and the reside that dripped hardened in a cobweb form. I see no fluid or liquid or corrosion on the boards. Thanks and have a great w/e. Dennis
  • Familycruzer Aug 18, 2008
    Here is the latest update on this set. Everything was working fine till yesterday. Now this is what happens. The set will make a poping sound and a horizontial 2 to 3" white line comes across the screen at the same time. Happens 2 or 3 times a minute. It's time to fix this before football regular season begins. What do I do to fix this problem. Thanks, Dennis
  • Familycruzer Aug 20, 2008
    Hi Big Irish,
    I checked all connections when the set first had problems, thinking something might be loose. I'll check again- Thanks Dennis
  • Familycruzer Aug 24, 2008
    Hi Big Irish,
    I'll check for fluid leaking on PCB and also try to isolate where popping noise is coming from. Thanks, Dennis
  • Familycruzer Sep 14, 2008
    Hey Big Irish Thank You for your help. Took out the chassic in the sunlight and was able to see the leaking fluid from the crt on the PCB.Cleaned it up and replaced four caps C2PO2-47m/35v, C2PO3-100m/16v, C2PO4-47m/16v & C2PO5-100m/16v. Put it back together and works as good as new. Added the cardboard over area of leak and I'll keep my fingers crossed. Thanks for your time and help and have a real nice w/e. Dennis
  • Familycruzer Sep 16, 2008
    Big Irish,
    Thanks for your help it was the crts after all. Sorry to hear that Ike gave you trouble. Hope the damage was minimal. Thanks for all your advice and help it was much appreciated. Dennis
  • sandy sander Dec 03, 2008
    video went out when using a wii system for 1st time after about 2-3 hours picture will show as mostly one color and faint then resorts to all black. II have never repaired a tv .any hope for home repair -- not afraid to do it -- just don't know anything about crts and caps and such
  • MICHAEL MULLINS May 11, 2010
    Good Day, Dennis;
    No video, has sound changes channels, ok. How do you change channels? Is it via a cable/sat box or direct ant/cable to TV?? Is audio from the TV or stereo system?? For no video, CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB.
Good Day, FamilyGuycruzer;
OKAY! Some way / how your TV started working all of sudden for at least 3-4 weeks then developed a different concern.
Well, let's think about this?????????????????? Still thinking
....................................., OH, maybe the HIGH VOLTAGE Cables are loose they are the right side of chassis (looking back) towards the rear of chassis. Check to make sure that they secure and any other connection are secure and seated properly.
big IRISH.
Posted on Aug 19, 2008
  • 927 Answers
Good Day, Dennis,
I'm glad it's working for the time being, which leads me to ask you to check this out, since the problem seems to come and go. Please remove front speaker cover, it just pops off, then remove the small black panel in the center TV front.
You want to look for fluid on PCB's, this 1999 model was known for this. The spots are very small, sometimes the size of a dime. They could be clear, or greenish with blackish type mold (corrision). Use bright light it's hard to see.
This fluid comes the TV's picture tubes, they use ethylene
glycol to cool the tubes. It's easy to clean with power off, unplug for safety reasons, use acid-tone, Finger nail remover, with paper towels & brush (tooth) to remove fluid.
Put heavy plastic or thick card board over affected areas.
Good Luck, big IRISH.
Posted on Jul 18, 2008
  • 1 more comment
  • MICHAEL MULLINS Aug 21, 2008
    Good Day, Dennis;
    If you can't hear where the popping is coming from, I will suspect still a fluid on PCB concern. Your TV may have fluid on CRT's anode area. I experience a Mit's Tv today that had no fluid last Wed and today, Wed, there was fluid on boards.
    The reason I suspected the High Voltage area is that 'popping' normally causes popping and picture distortion and not a Dc circuit area. Try to isolate where the popping is coming from.
  • MICHAEL MULLINS Aug 24, 2008
    Good Day and Good LuckbI.
  • MICHAEL MULLINS Sep 16, 2008
    Good Day; Dennis;
    You should be okay now. The liquid is hard to see. That's why I stated bright light.
    Sorry, for the late responce but just got hit with IKE, been busy. Thanks and glad you found the problem, big IRISH.
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
set tv on fire,then threw it down the stairs...
now,why would i tell you how i fixed it for 'free' ,when you
charge ''me'' for answers..hmm
Nov 02, 2009 | Mitsubishi VS-50705 50" Rear Projection...
VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
Jun 27, 2009 | Mitsubishi VS-50111 50" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
The input 3 has been turned off, how do i turn it back on?
it can be turned on and off in the menu. under parental control. you may need a code to turn this on or off.
Dec 27, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Cannot adjust convergence
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Nov 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50va2 50 in. projection tv
You need go to set up andjustment mode and change the option of HOME THEATER to OFF position.
May 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi 50" VS 50605
we need to know if the lines are of different colors or are they white and the screen is too bright ?, 275.00 seems a lot just to get it check out but it all depends were you are,in NY that could be a going charge but in pittsburgh it seems too much,please let us know what the lines look like.
Oct 09, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
172 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
