Question about OKI Office Equipment & Supplies
Oki c5650 i have replaced toner catridges error 543: k toner sensor error help
  • digicircle Aug 23, 2008
    Toner sensor error; replace a new toner; problem remains
  • Anonymous Dec 02, 2008
    543 K toner sensor error - problem remains after i have replaced toner cartridge OKI c3300n
SOURCE: 543 K: Sensor Error
I had the same problem, after lots of work and fooling around..............Place a piece of white paper in the window where the sensor looks
Posted on Jul 25, 2008
Touch2Heaven
  • 145 Answers
SOURCE: toner sensor error
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Posted on Oct 18, 2008
  • 4 Answers
SOURCE: Oki Printer c3200 error code
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Posted on Oct 27, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 13 Answers
SOURCE: I have replaced the toner cartidge and it is
take a look here :
http://www.c5200.co.uk/index.asp?menumode=0&content=sensorerror
Posted on Oct 13, 2009
OKI C5650 231 FATAL ERROR 03
I tried putting 1.5mm of plastic foam under the RFID chip to raise it up in the toner cartridge. This seemed to work.
Jan 17, 2012 | Office Equipment & Supplies
Printer OKI C5650: "POWER OFF/ON 928:FATAL ERROR"
TRY REMOVING ALL CONNECTIONS & THEN RESTART.REMOVE CATRIDGE AND RECONNECT
Sep 24, 2010 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
I have replaced the toner cartidge and it is displaying 543 sensor error on my OKI 550
take a look here :
Oct 13, 2009 | OKI C3200n Led Printer
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Sep 01, 2008 | OKI C3200n Led Printer
Message to order new k immager
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Mar 09, 2008 | OKI C5200n Laser Printer
Toner sensor error
Feb 11, 2008 | OKI C5200n Laser Printer
1,307 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
