Question about Husqvarna Viking 1
How to remove side panel
I have a husqvarna 6010, and can't get the side panel off. I can't figure out how to remove the hand wheel.
Stevanos said: hand wheel is clipped on and must be pulled off, but requires some muscle. I had to pry it off.
I was chipping the inside edge of the wheel with one flat blade screw driver as I tried to pry it off. I finally got it off with using even pressure by using a putty knife on one side and the flat blade screw driver on the other side. Thanks for the help stevanos!
Posted on Nov 19, 2009
...mine could not be pried off since the clip was entangled up with threads debris that had been accumulated over the years. The solution was to remove the base of the machine, unscrew the side panel and bend it so it could - to some extent - be rotated around the hand wheel to the side. That gave me some opening to could come in and remove the the nest by 'minimal invasive surgery'.
Thanks,
Mattias
Posted on Nov 13, 2011
    Problem Solver:
  • 16 Answers
Hand wheel is clipped on and must be pulled off, but requires some muscle.
Posted on Jul 03, 2008
The plastic gear in the 6010 Viking is cracked and I'd like to replace it.
Have you searched the internet?
Absolute Sewing Machine Information Husqvarna Viking Service manual
Sewing Machine Viking 6000 Cam Replacement (not sure if it is the cam gear that needs replacement)
If you are unable to find instructions, perhaps you can find an independent sewing machine repair person who would be willing to do it for you.
Jun 03, 2016 | Husqvarna Sewing Machines
Wound thread around the hand wheel
You should be able to pull the cover of the hand wheel off. Just firmly grab the hand wheel and pull straight back.
Feb 24, 2014 | Husqvarna Lily 540 and 550
Thread caught in spinning handle
The hand wheel is just snapped on. If your thread is tight around the shaft it will be very hard to remove and will have to be gently pried off with a pair of screwdrivers.
Feb 05, 2014 | Husqvarna Sewing Machines
I have a husqvarna H Class E10 sewing machine. The hand wheel has tighten up on me. I can not loosen it.
I suspect the main bearings and other rotating parts need to be cleaned of old lubricant and regreased. This obviously requires dsassembly of the maching. Unless you're a mechanic, leave it to the repair person.
Feb 21, 2013 | Husqvarna Sewing Machines
Hand wheel not moving
Check bobbin area. Clean feed dogs with brush to remove lint balls & any loose threads. Use gentle back and forth motion on hand wheel to see if you can loosen debris. Be VERY gentle so you don't interfere with timing. Usually you will bring up one thread caught in feed dogs and you can sweep it out. If that's case here, I recommend inserting new needle, flat side back and make sure you raise presser foot before rethreading to open tension discs. Good luck. Jimmy
Apr 04, 2012 | Husqvarna Husky 165
My viking 6570 sewing machine needle will not pick up the bobbin thread
Remove the bobbin case and lean the machine back. Bring the needle down as low as it will go using the hand wheel. Locate the tip of the needle in the bobbin area. Rotate the hand wheel forward and as the needle rises, you should see the tip of the hook cross the back side of the needle, moving left to right. If it is crossing below the eye of the needle, find a qualified repairman. If it crosses above the eye, try a new needle and make sure that the flat side is installed toward the back.
Oct 02, 2011 | Husqvarna Viking 1
My Husqvarna Zig Zag Model 10 30 has seized I can't even turn the wheel for the needle manually, do I just oil as many parts as I can and keep trying?
Yes, but try turning the hand wheel towards the back of the machine (if you are facing the hand wheel, turn it clockwise) and pick up some self penetrating oil such as Tri-Flow. I would bet that the bind is either behind the hook or on the top shaft towards the right side.
-Chris
Jun 14, 2010 | Husqvarna Designer I
The foot pedal does not make the machine sew but it sounds like the motor is working. The machine does work when you manually turn the hand wheel. It was working before I put the cover on the machine.
Is the belt broken ?
Unplug, remove the side panel at handwheel and check....use the old one as a sample to take with you to buy a new one...DO NOT adjust the belt too tight on installation, it will overburden the motor.....or have the repair shop do the job for a little investment in peace of mind
Jul 31, 2009 | Husqvarna Viking 1
Sewing Machines Logo
300 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
