Question about HP Photosmart 2610 All-In-One InkJet Printer
Copying function This printer has worked very well.  Until this morning.  The copying function takes about 4 minutes to copy a page.  The light moving across the page is going at a snail's pace.  Any ideas?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this copying text or photographs?
    Problem Solver:
  • 12 Answers
How much time it is taking to print a self-test page
Posted on Jul 07, 2008
Prints a black page when we try to make a copy
Open the top cover and make a copy. Does the lamp under the glass light up brightly and move across the underside of the glass ? If not the lamp has burned out or the thermal limiter has blown.
Dec 27, 2012 | Copystar Ri-2530 Printer
Cannot get printer to copy
Start up your printer. Wait until it has powered on completely before beginning.
Open the printer's lid and place your item on the copying surface with the side you want copied face-down on the glass. Double-check the alignment.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed .Choose the kind of copy you want: black-and-white or color. You also may have to select the kind of paper that you are copying.
Size the copy to the page if desired. Some multi-function printers allow you to expand or shrink the original to fit different sizes of paper.
Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Press the "Start" button. Other names for this might be the "Copy" or "Print" button.
Remove the pages as they are delivered from the printer's feeding mechanism. Do not tug on the copies as they come out. Let them fall into your hands.
Take care.
Jul 05, 2010 | Brother Office Equipment & Supplies
I cannot get the printer to copy anything, it just goes into the align mode. It will print things from my computer.
Start up your multi-function printer and computer. Wait until it has powered on completely before beginning.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed.
.Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Take care.
May 15, 2010 | Office Equipment & Supplies
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
I am unable to set my Canon M155 Printer for the Copy function.
Try scanning and check the image.If it's same the problem is in ribbon cable of scanner.
Nov 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Copying on my Lexmark 6500 four function fax, copier, scanner, pr
turn your copier and all attachments off wait ten minutes reboot should b ok
Jan 19, 2009 | Office Equipment & Supplies
I can print but can't copy or recieve faxes
you can try the following steps .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
The copy function prints a solid black page?
Do you see the light going all the way across? The printer may be having power issues. You should make sure it is plugged into the wall and not into a surge protector or a power strip.
If the light is not coming on then there is an issue with the scanner bulb and if the printer is plugged into the wall then you should call hp and see if you can have it replaced.
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
