SOURCE: Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
SOURCE: How do I remove my electric cooktop...the conduit
On link below is a install manual It might not be yours but they are all pretty much the same. It will tell you how to install. You just do the reverse to remove.
Also you do not un wire the cooktop from the cooktop but from the junction box in the wall. Please make sure the breaker is turned off before you un-wire it.
http://www.jennair.com/assets/product/JEI0430ADS_Installation%20Instruction_EN.pdf
Testimonial: "Thankyou very much for the link"
SOURCE: 30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
SOURCE: After spraying stainless steel cleaner on the
Yes, the moisture is probably the problem... Here
Keep on Clicking
heatman101
SOURCE: Cooktop Model, Maytag JED8430ADB. When I tried to
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
