Connecting multiple A/V cables to 1 TV
My TV currently has spots for 3 different input devices, currently I use 1 for my Nintendo Wii, 1 for a DVD player, and 1 for cable TV.
I'd like to know if there is a product avilable that would allow me to connect multiple A/V cables to 1 A/V input slot? Much like a surge protector allows you to plug multiple electronic devices into 1 power outlet.
I don't recall the brand of TV, but I know it is a HD flatscreen TV.
  • zantar412 Jun 30, 2008
    And to follow up a little, the reason I ask is because I intend to buy a playstation 3, the TV is mounted, so constantly unplugging the Wii to plug in the PS3 and vice versa would be rather difficult and frustrating.
  • cspagnola Jan 12, 2009
    I have the same issue. My Samsung 46 LCD is mounted on the wall and even though it has many A/V inputs, I currently have the cable box (to supply the HD content) connected thru the wall to the TV. The cable guy said I have to connect everything thru the cable box and feed the TV because the cable box operates the TV....also because the wires are going thru the wall there is only one connection. So I need a device to connect multiple devices (WII, XBOX, DVD player, etc...) into the input in the cable box that feeds the wall wires to the TV....Will a receiver do the trick?
    Scholar:
  • 78 Answers
Hi zantar412,
Yes, there are devices to help you. You should shop for an “RF Modulator.” While the intention of this box is convert an A/V signal to RF for older televisions, many modulators offer multiple inputs which can be chosen with a switch. Be sure to check both the input and output options on the box that you buy to ensure it will be compatible with your components and television.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 30, 2008
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Apr 01, 2011 | Nintendo Wii Console
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
How can i directly connect a LG H30 TV, or a PS3 or a Wii to a Regent HT391 sound system? Is it possible to? So far the only 'surround sound' I can achieve is by connecting my tv thru the cable box...
According to the various vendors that carry this model, the unit has multiple inputs to accommodate gaming systems, dvd, tv, etc.
Look on the back of your system and see if there are inputs labeled as Game, DVD, TV, etc. You should be able to connect each component, and use the remote to switch between the multiple sources.
Good luck.
Feb 03, 2010 | Durabrand HT-3915 System
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
What is Input Select and how do I find this on my TV?
Typically, 'Input' is an option found on your television's remote control, not on the TV.
If you have your remote, look for a button labeled 'Input' - pressing this allows you to change the input that the television is using at the current time (ie. you can have multiple devices [GameCube, a DVD player, and an XBOX (for example)] connected to your TV through the various inputs on the back (where all the cables go) and select (or jump) between the various devices. This means that you don't have to unplug and plug in each different device everytime you want to use it)
Jan 08, 2009 | Nintendo GameCube Console
Wii has no color
Are you connecting you Wii to a progressive scan TV input (2 for audio (red)(white), 3 for video (yellow)(blue)(red)?
It's possible you have the red audio and red video inputs switched.
If you have the regular AV-Cable (2 for audio (red)(white), 1 for video (yellow)), and your TV has 5 inputs (progressive), look for the 3 inputs (2 for audio (red)(white), 1 for video (yellow). If it doesn't, connect it to a VCR and run the Wii through the VCR input.
Dec 25, 2008 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Connecting a wii to a RCA Scenium
Sorry but I have to ask, are you sure the cables were plugged in correctly on the bigger set? Try using your tv's input button to scroll through the different inputs until you come to the one where the Wii is plugged in. You can check which one by looking where you plug the cables in. i.e. line 1, line 2, component 1, etc. Hope this helps.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
1,365 people viewed this question
Top Televison & Video Experts
