Question about Philips Lands Phones
PHONE SE445 I bought this phone and the problem is when i finish a call and turn it off I cannotconnect to my computer that tells me there is no dial tone. How do I overcome this please. Ken
  • fishy123 Aug 16, 2008
    We added an additional filter and that solved the problem........thanks for trying guys Ken
How do you connect the se445 to the computer?
Because i think that is not possible
Posted on Aug 15, 2008
I have a Uniden DECT 3216 and want to divert calls to my mobile after hours. Is this possible please?
It is a landline phone ?
Divert on no answer to the mobile number using easy call codes into the landline. code should be *61{mobile phone number}#
dial into uniden phone when dial tone heard like when phone is in talk / dial mode ready to make a call
dial #61# if you wish to turn it off
https://www.telstra.com.au/help/download/document/home-features-user-guide-c020.pdf
This is telstra's codes but your phone provider will have control codes that may be even the same as the
telstra codes
you may want immediate call forward this is *21{number of phone}# then #21# to turn it off
Nov 03, 2017 | Uniden Lands Phones
How to stop continuous beeping by Philips se445 phone
Some cordless phones will give non stop beeps to indicate that the battery reached its lifespan and can no longer get fully charged. replace battery. If battery is okay, check for sticky key on keypad? You'll be surprise how often the keys you press get stuck in its seat - same thing happens to computer keyboards then the computer beeeeeeps and the user has no idea why. Always keep all phones off your desk when you having your coffee :) Can turn into a sticky mess if you spill :) You can clean your phone keypad with a quck dry solution available at computer shops as it is also used to clean between the keys of the computer keyboard. its called the "All purpose computer cleaning spray"
Hope this helps
enjoy:)
Sep 08, 2014 | Philips SE445 Cordless Phone
I can't understand the language, how to change it?
You will never Find a language that will suits you
Jan 07, 2012 | Philips SE445 Cordless Phone
Instruction manual for Philips SE445 cordless phone
Hello
Either send your email address to me by Fixya, or seand a mail to me. I've the manual of your chordless phone, in adobe acrobat printable version, and I'll send it to you by return mail. I can't send it to you by this site, as it is a big file. OK.
Mar 17, 2011 | Televison & Video
How can I obtain/generate a '+' sign on my Philips SE 445 touch house phone, to enable me to dial overseas? Regards L W C
Please press long on the 0 key. That should bring up the + sign.
Hope this helps. If so, please consider rating this solution.
-regards,
M
Mar 13, 2011 | Philips SE445 Cordless Phone
Are one touch dialing board not working
When sending, try using a analog phone, and dial the number you are calling. Make sure it is the correct number. You might hear someone pick up the phone, or you will get a recording messege. This will tell you if the phone is the correct number you are trying to dial. When you are finished, plug in the phone line back into the correct jack on the fax machine.
Once you hear the dial tone, your phone is working.
If you can send a fax, and the machine does not send it, then the machines fax board might not be working.
There are other questions I like to ask about the phone line. Are you using a adaptor to convert the analog signal to digital? If this is the case then the adaptor may be causing some problems with your faxes.
Good luck.
Feb 27, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Update trooble
take it to the phone repair shop and tell them i want to fkash my phone, that would cost 10$
Feb 26, 2009 | Nokia 6300 Cellular Phone
Setting the speed dial numbers
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Nov 03, 2008 | NorStar T7316E Corded Phone
We have an se445 cordless phone/answerphone. with answerphone on, the line rings 4 times then stops briefly before continuing to ring instead of cutting onto answerphone. BT line has been checked and gain...
Regarding the Philips SE445 cordless phone/answerphone. I posted my problem where it rings 4 times then continues to ring without cutting into the answerphone. My phone is now fixed and working as it should which is great. I was unable to make calls because I had no dial tone and although Virgin checked my line and said it was fine, it obviously wasn't. The problem was with the line in the Exchange Box - the big green boxes that are located on the roadside - the line was broken there. Once fixed, I had my dial tone and the SE445 is working perfectly. To nomad1066, I would insist that BT check their Exchange Boxes as this is probably where the problem lies. Check whether you have a dial tone. Hope this helps.
Jul 24, 2008 | Lands Phones
Lands Phones Logo
54 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
