Drum wont spin
Good morning, i have a kenmore washing machine that yesterday stopped spinning, It will run through every other cycle until it gets to the spin cycle it stops and this is on every setting. It was working fine until yesterday when i did something different, i was told a little pine sol in the water would help with a sour smell our clothes have been getting but i cant see that stopping it from spinning. Any advice would be appreciated. Thank you Allen
  • acook Jul 01, 2008
    thank you for responding, i will try that and let you know
  • 5,911 Answers
The problem is your lid switch. This is a common problem that can be easily fixed. If you click on the following link, it gives you step-by-step instructions on how to replace a lid switch.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Typically, the lid switch becomes loose, or the contacts eventually fail from repeated use. If you open and shut the washer lid, you should be able to hear a "clicking" sound as the lid switch activates with the lid closing.
The switch is located on the the right-hand side of the lid on some models, and is activated by a plastic piece on the lid, called a "lid strike". Make sure the lid strike is still intact.
On other models the lid switch is located on the left-hand side under the washer casing near the left lid hinge. It is activated by a small rod that closes the lid switch contacts when the hinge pivots. Sometimes a simple adjustment of this rod will cure a lid switch problem.
If you post back with your model number, I can tell you which type of lid switch you have. Typically, they range in price form about $25 to $35. I hope this helps you.
PS Pine Sol would not cause this problem. I think this is just a coincidence.
Posted on Jun 30, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
