Question about Canon DR-9080C Path-Through Scanner
Canon DR-9080C CaptrePerfect 3
I need captreperfect software for DR-9080C scanner. I searched for but but everywhere updater version is available. How i can get the CapturePerfect software. pl help me
  • 490 Answers
Captureperfect 3 is not available on the Net. Only version 2.311 is available. (It may also be called upgrade) Download this and this can meet yr basic requiremnts. http://software.canon-europe.com/products/0010035.asp
The upgrades wont work without ver 3.0!
S. Mohan 94441 66426
Posted on Jun 30, 2008
Set up disk for canon DR 9080 path through scanner
Hi Joseph, you should be able to find the driver for your OS on the Canon website here. imageFORMULA DR 9080C Color Production Scanner
Apr 10, 2014 | Canon DR-9080C Path-Through Scanner
Lower reading unit broken?
Ensure you have selected Duplex option. Canon DR 9080C uses LED lights and hence the chances of failure of light source is fairly low. Try scanning in Color.
The scan module, if required, can be replaced and is available in the market between $600 to $750. Please ensure that the module is faulty before replacing. (the upper and lower modules are interchangeable, except for a few plastic parts)S. Mohan, Chennai, India
Feb 24, 2012 | Canon DR-9080C Path-Through Scanner
We purchased a business and a Canon dr-9080c. I have the driver installed for the Windows 7 64 machine, but we need to know what software to use to run it. The original disks are not with the machine
You need CapturePerfect version 3 to run it. CP3 has quite lot of features for easy scanning. It is not available free on the Internet. CapturePerfect2 version is available at
http://software.canon-europe.com/software/0022439.asp?model=
but this has limited features.
Aug 19, 2011 | Canon DR-9080C Path-Through Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Feb 23, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C paper tray lift broken
Michael, U can buy 9080C service manual at tradebit.com 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Jan 30, 2009 | Canon DR-9080C Path-Through Scanner
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
1,062 people viewed this question
old marine
old marine
