Question about Husqvarna Viking 1
Reverse sewing button stuck HELP!!
Model 6430 Viking has the reverse button located in the center of the stitch length dial. It is firmly jammed in the reverse position causing the machine to sew ONLY in reverse.
When I pull firmly on the button it will sew forward but goes back to reverse when I let go...It seems to be attached to a spring, inside. Possibly the top knob has not been installed correctly???? I have the same problem but for the husqvarna 2000 SL model. The reverse button appears to be stuck on. Tried the instructions in the manual to no avail.
  • 1 more comment
  • Max24 Oct 09, 2008
    I have the same problem with a husqvarna 2000.
    It is stuck in reverse.
    A cam mecanism inside is very "sticky" and will not return to forward even though the spring is still attached.
    Any suggestions.
    Regards, Max
  • Anonymous Jan 28, 2009
    I too have a Viking 64 30 with a knob stuck in reverse. Is this something I should take in or can it be fixed at home?
  • Anonymous Mar 04, 2009
    viking 6430 stuck in reverse, reverse button seems loose won't stay up. i can sew if i turn my machine around so i can sew in reverse. is the reverse know broke or just stuck some how
    Problem Solver:
  • 16 Answers
The mechanism requires lubrication from the back, would be best to have machine serviced.
Posted on Jul 03, 2008
4 Suggested Answers
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
  • 46 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
Posted on Jul 25, 2009
  • 371 Answers
SOURCE: stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website http://www.husqvarnaviking.com and selecting "dealers" link.
Posted on Feb 11, 2010
Viking/Husqvarna 5710 sewing machine is stuck in reverse. Reverse button isn't stuck, but doesn't pop out by itself anymore. Stitch dial isn't in between stitches. Put wd40 in the insides, didn't help
Uh-oh. Don't use WD-40 on your machine... WD-40 becomes sticky with time and will seize the mechanics...
Wondering if there is a spring under the R button that perhaps is broken or collapsed.
Apr 27, 2017 | Sewing Machines
How do I center the needle on a Viking 6430; there is no eccentric adjustment on the needle bar frame on this model.
Am having difficulty finding information on this machine.
http://husqvarna-viking-service-repair.blogspot.com/p/husqvarna-viking-service-manual-models.html
http://sewingnz.blogspot.com/2010/09/husqvarna-viking-service-manual.html
Perhaps this machine is a left-needle position machine, ie the normal straight stitch sewing position is on the left, not centered. There are quite a few machines out there with this feature, Necchi is another. The needle only swings right when a decorative or zig-zag stitch is selected.
Stitches and Seams Review Viking 6010 Sewing Machine (See #3 under Dislikes.)
If it is actually a center-needle position machine, it is probably out of alignment. There is most likely an adjustment. For more help, you can also join some Viking user groups on Yahoo. Most members are very dedicated to the brand and would be able to provide some very helpful advice.
Nov 28, 2015 | Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
Husqvarna Classic 100 sew machine , pressed reverse button, now it sew reverse only!!! Please help! i pressed, i hold, turned off and on, nothing....... any ideas?
There is a permanent reverse position on the dial button behind the reverse where the stitch length is located. Check to see if you have positioned the knob to permanent reverse. The setting looks like a "U" turn arrow.
Feb 18, 2011 | Husqvarna Scandinavia 100 Sewing Machine
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Oct 07, 2009 | Husqvarna Viking 1
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
1,829 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
