Question about Garmin eTrex GPS Receiver
Etrex satellite problem
Hi - I've tried your global reset sequence in the service mode, but I don't seem to be losing any data ... so I'm not sure the global reset is working and I still can't find the satellites. Do you have any more sugestions?
Cheers TomSM
  • 1 more comment
  • TomSM Jun 30, 2008
    Hi Benimur, I didn't know whether the second one was relevant to my etrex as I don't have a button on the front. So I tried the method using the enter button instead and it reset ....... Wahey!!!Thanks a million. Its now finding satellites fine. Cheers you're a star.
    TomSM
  • don_scott365 Jul 05, 2008
    seems gps is in work with gps off mode will not change setting gps is etrex legend c thank you don
  • wcharleton Jul 16, 2008
    garmin etrex legend won't find satellites. have checked settings per manual. all were ok.
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the update.
Have you tried both methods?
Posted on Jun 30, 2008
  • Louie  Role
    Louie Role Jul 01, 2008
    Glad that it is working again and appreciate the rating.
  • Louie  Role
    A favor, if it is OK with you, I would appreciate if you can likewise re-evaluate the rating in your original posting here. It kinda lowered my overall percentile. Thanks again in advance.
My garmin 530hcx has locked up on the opening screen...is there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 | Garmin GPS
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
My etrex legend won´t detect any satellites.
Make sure its not stuck in simulator mode in the setup menu. then update your firmware on the device. you can get it from www.garmin.com
if that doesnt work then there is something internally wrong with it and will need to be sent in for repairs.
Aug 14, 2009 | Garmin eTrex Legend GPS Receiver
ETREX LEGEND HAS 1 VERTICAL LINE ON SCREEN AND WONT SHUT OFF UNLESS YOU PULL BATTERYS
Have you updated your unit's software from the Garmin site? There was a new satellite launched in 2008 which has been causing problems, and the new update fixes this.
Mar 03, 2009 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Etrex reset instrucitons
If your Garmin eTrex is a Legend and you want to do a "Reset", pls try:
Hard Reset:
With the unit turned off, press and hold the follow buttons: PAGE + Enter on the click stick. Then press and release the POWER. The unit will power up asking if you want to release all user data. Select yes, and the unit will be reset. After the master reset, place your unit outside, so that it has a clear view of the sky for 25 to 30 minutes for the unit to acquire new almanac data.
This was originally posted here and a wealth of other Legend information.
Alternately, this has been posted here at FixYa as well. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 04, 2008 | Garmin eTrex Legend GPS Receiver
Etrex - can't find satellites anymore. Just stopped one day after downloading Points to my pc
To my knowledge, a reset on a Garmin eTrex would require:
Holding down the PAGE and PAGE UP buttons while simultaneously powering the unit. The Garmin eTrex will enter the service mode/display:
- Bravo Version
- Software Version
- Time
- Internal temperature of unit
- Battery voltage
- External voltage
- Button presses
- Other tech info
You can also perform an LCD display/screen check by pressing the PAGE button 2X.
A firendly word of advice: While entering the service mode is interesting and useful, be careful which buttons you press because it is also possible to rest the unit to factory settings within this mode. Pressing "up"+"enter"+"on/off" keys in service mode will reset the eTrex to factory defaults. All presets and data will be lost.
To exit just turn it off as normal, and then turn it back on as normal. Unless you deliberately reset the GPS, nothing should have changed.
Alternately, you can try: Hold down the find, click-stick, and page buttons. Press the power button, and when the title screen appears, release the buttons. This will clear all memory (you will lose all waypoints, etc. back them up first).
Find button: bottom button on the left
Click stick: the button on the face of the unit
Page: the top button on the right
Power: the bottom button on the right
Jun 26, 2008 | Garmin eTrex GPS Receiver
Garmin Vista Shutting down and freezing up
People! The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
May 27, 2008 | Garmin eTrex Vista GPS Receiver
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here: http://www.gpsinformation.org/dale/secret.htm#reset
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex GPS Receiver Logo
225 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
