Question about Honeywell Heating & Cooling
I replaced the filter in my HVAC system and since then, the temperature has not held at the level it is set for. I am concerned something is wrong.
  • 182 Answers
Was the filter you putin the same as you removed?Check to make sure the doors are tight on the furnace.Run ac and heat at thermostat to make sure everything works.check to see that outdoor unit runs when ac is on.
Posted on Jul 04, 2008
Air blowing cool on passenger side warm on driver side how to fix this
sounds like you have a temp door motor problem on the drivers side. the motors seize/stick and have to be replaced.
Aug 09, 2015 | 2005 Buick LeSabre
Air Con
no the pipes should not be cold and wet but if you just have stop using the aircon recently it will do that for a while till all the gas is out of the system so yes its sorta normal
Oct 02, 2008 | 2001 Chrysler PT Cruiser
What causes a/c to blows cold on driver's side and hot on passenger side ?
There is a little motor on the heater box under the dash that needs to be replaced. It's called a blend door actuator...
Mar 16, 2015 | 2004 Cadillac DeVille DHS
Why would gauge cluster not funtion until interior temperature reaches a certain level?
Could be a weak connection in the wiring harness going to the cluster, or inside the key switch.
Feb 16, 2015 | Cars & Trucks
The heat in my 2006 grand prix will not get hot. We replaced the thermostat and got nothing. So I got the radiator flush and force filled again. Still nothing. Temp of the motor still gets to the middle,...
Are the 2 tubes that go to the heater core getting hot? If so, then the blend door is not opening to allow heat to get to the cabin.
Possible vacuum motor problem, either disconnected, or the controller for the blend door is broken is likely problem.
Troubleshooting by Symptom Poor Heater System Performance CAUTION
Check all fluid levels and adjust as needed, before operating vehicle for extended periods at idle.
  1. Start the engine.
  2. Idle the engine until the thermostat opens (upper radiator hose will be hot) Is the engine at normal operating temperature (approx. 200° F)? If yes, go to the next step. If no, go to step 16.
  3. Set the mode selector to FLOOR mode.
  4. Set the heater control selector to the warmest temperature setting.
  5. Set the blower speed the lowest setting.
  6. Carefully feel the inlet and outlet heater hoses at the heater core. Is the inlet heater hose significantly hotter than the outlet heater hose? If yes, go to step 14. If no, go to the next step.
  7. Set the mode selector to PANEL mode.
  8. Select the maximum blower speed.
  9. Select the warmest temperature setting.
  10. Place a thermometer into the center I/P PANEL air outlet and affix a second thermometer to the heater core outlet heater hose.
  11. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 13.
  12. Inspect and repair the cowl, cowl area, recirculation door, and the HVAC evaporator/heater core case for cold air leaks. Repair any problems found, go to step 17.
  13. Inspect the temperature door operation. Repair any problems found, go to step 17.
  14. Turn OFF the engine. Back-flush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Is the inlet heater hose feel significantly hotter than the outlet heater hose? If yes, go to the next step. If no, go to step 17.
  15. Replace the heater core. When the repair is completed, go to step 17.
  16. Check for low engine temperature problems, Repair or replace as needed, go to step 17.
  17. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Air Door Actuators/Motors Removal & Installation Recirculation Actuator To Remove:
  1. Remove the right lower instrument panel (I/P) insulator.
  2. Remove the glove box assembly. Recirculation actuator (Typical) gm-10-00-3695.gif
  3. Remove the mounting screws and recirculation actuator from the HVAC module assembly.
  4. Disconnect the recirculation actuator harness connector.
To Install:
  1. Align the recirculation actuator slots with the flats on the actuator door shaft.
  2. Install and secure the recirculation actuator on the HVAC module assembly with the mounting screws.
  3. Connect the recirculation actuator harness connector.
  4. Install the glove box assembly.
  5. Install the right lower I/P insulator.
  6. Calibrate the recirculation actuator.
Mode Actuator To Remove:
  3. Remove the mounting screws and mode actuator from the HVAC module assembly.
  4. Disconnect the mode actuator harness connector.
To Install:
  1. Align the mode actuator slots with the flats on the actuator door shaft.
  2. Install and secure the mode actuator on the HVAC module assembly with the mounting screws.
  3. Connect the mode actuator harness connector.
  6. Calibrate the mode actuator.
Air Temperature Actuator Right Side To Remove:
  2. Remove the glove box assembly. Air temperature actuator (right side) gm-10-00-4356.gif
  3. Remove the mounting screws and right air temperature actuator from the HVAC module assembly.
  4. Disconnect the right air temperature actuator harness connector.
To Install:
  1. Align the right air temperature actuator slots with the flats on the actuator door shaft.
  2. Install and secure the right air temperature actuator on the HVAC module assembly with the mounting screws.
  3. Connect the right air temperature actuator harness connector.
Left Side To Remove:
  1. Remove the left lower instrument panel (I/P) insulator. Air temperature actuator (left side) gm-10-00-4357.gif
  2. Remove the mounting screws and left air temperature actuator from the HVAC module assembly.
  3. Disconnect the left air temperature actuator harness connector.
To Install:
  1. Align the left air temperature actuator slots with the flats on the actuator door shaft.
  2. Install and secure the left air temperature actuator on the HVAC module assembly with the mounting screws.
  3. Connect the left air temperature actuator harness connector.
  4. Install the left lower I/P insulator.
  5. Calibrate the mode actuator.
Oct 18, 2010 | 2006 Pontiac Grand Prix
I have a 1999 Chevy Malibu and the AC turns from inside air output to outside output on it's own. You can push the inside air button and it will go back and then in a second or two it will go back to the...
Yes , the Refrigerant level is good , I would say the control panel is bad , or there is a problem with HVAC Air Delivery/Temperature Control Circuit Description
The vacuum actuators move the air valves in the HVAC system (except the temperature valve). Vacuum is applied to the actuators through the mode selector in the heater A/C control assembly. The mode selector consists of a rotary vacuum switch. The rotary vacuum switch supplies vacuum to the vacuum actuators according to the operating mode selected by the driver. A small servo motor moves the air temperature actuator. The small servo motor positions the door according to the voltage level from the temperature selector in the heater A/C control assembly. The temperature selector is a potentiometer positioned by the temperature control knob on the front of the heater A/C control assembly.
When the ignition switch is in the RUN position, battery voltage is applied to the air temperature actuator. The actuator receives ground at all times through the following components:
• CKT 251
• Ground G204
The temperature selector is a potentiometer with a wiper arm. The wiper arm is electrically tied to the air temperature input through CKT 733.
When the temperature selector is moved between COLD and HOT, voltage to the control input varies between 1 and 12 volts. The temperature valve motor solid state circuitry performs the following tasks:
• Looks at the control input voltage
• Moves the motor to correspond to the control input voltage
The temperature valve moves for the following reasons:
• In order to allow the air to pass through the heater core
• In order to allow the air to pass around the heater core
This control achieves the desired passenger compartment temperature.
HVAC Air Delivery System Check
Step
Action
Yes
No
Start the engine.
Turn the blower motor fan ON and select an air outlet mode.
Does air flow out of the selected HVAC outlet ducts?
Go to Step 3
Go to Step 2
Did the customer concern mention that the air discharges out the correct ducts at first, but then changes during higher engine RPM?
Go to Step 7
Go to Step 3
With the engine running, cycle the HVAC controls through all the modes.
Does the air come out of the selected outlet ducts?
Go to Step 18
Go to Step 4
With the engine running, take a vacuum reading at the manifold vacuum port that supplies vacuum to the HVAC vacuum control assembly.
Is there engine vacuum?
Go to Step 6
Go to Step 5
5
Repair the no vacuum condition.
Is the repair complete?
Go to Step 18
6
Take a vacuum reading at the vacuum supply line at the HVAC vacuum control assembly.
Is the vacuum reading the same as the engine vacuum?
Go to Step 11
Go to Step 8
7
Disconnect the vacuum supply line from the HVAC vacuum control assembly.
With the vacuum gauge connected to the vacuum supply line, re-start the engine and turn the engine OFF.
Does the system lose vacuum after turning OFF the engine?
Go to Step 8
Go to Step 11
8
Inspect for leaking or collapsed vacuum lines between the engine manifold vacuum port and the HVAC vacuum control assembly.
Are the vacuum lines leaking?
Go to Step 9
Go to Step 10
9
Repair or replace the collapsed or leaking vacuum line.
Go to Step 18
10
Replace the vacuum reservoir tank.
Go to Step 18
11
Using an external vacuum source, apply vacuum to the appropriate vacuum line at the connector to the HVAC vacuum control assembly.
Does the actuator retract?
Go to Step 17
Go to Step 12
12
Inspect for leaking or collapsed vacuum lines between the actuator and the connector to the HVAC vacuum control assembly.
Go to Step 9
Go to Step 13
13
Disconnect the vacuum line from the actuator.
Apply an external vacuum source to the actuator.
Did the actuator retract?
Go to Step 14
Go to Step 16
14
With the actuator disconnected, inspect the door for binding.
Does the door move freely?
Go to Step 16
Go to Step 15
15
Repair the appropriate binding door.
Go to Step 18
16
Replace the appropriate vacuum actuator.
Go to Step 18
17
Replace the HVAC vacuum control assembly.
Go to Step 18
18
Cycle the HVAC controls through all modes to verify proper operation.
Did you correct the condition?
System OK
Apr 05, 2017 | 1999 Chevrolet Malibu
The rear heater does not heat up when switch is on
  1. Start the engine. Allow the engine to idle. Does the engine reach normal operating temperature? If yes, go to the next step. If no, go to step 8.
  2. Allow the engine to idle. Select the FLOOR mode. Select the minimum blower speed and the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 6. If no, go to the next step.
  3. Install a thermometer into the center I/P PANEL air outlet. Secure a thermometer to the heater core outlet heater hose. Select the PANEL mode. Select the maximum blower speed. Select the warmest temperature setting. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 5.
  4. Inspect and repair the cowl, recirc door, and the HVAC module case for cold air leaks. If problems are found and repaired, go to step 9.
  5. Inspect the temperature door operation. Perform any necessary repairs. When repairs are made, go to step 9.
  6. Turn OFF the engine. Backflush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to the next step. If no, go to step 9.
  7. Replace the heater core. When the repair is complete, go to step 9.
  8. Repair the low engine temperature concern. When the repair is complete, go to step 9.
  9. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Insufficient Defrosting
  1. Start the engine, select the DEFROST mode, and select the maximum blower speed. Does sufficient air flow from the defroster outlets? If yes, go to the next step. If there is insufficient airflow, go to step 9.
  2. Measure the engine operating temperature. Does the engine reach normal operating temperature? If yes, go to the next step. If the engine does not reach normal operating temperature, go to step 7.
  3. Select the minimum blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 10. If the hose temperature is not right, go to the next step.
  4. Test the operation of the A/C compressor clutch. Does the A/C compressor clutch engage? If yes, go to the next step. If the compressor clutch does not engage, go to step 6.
  5. Repair or replace the A/C compressor clutch. When the repair is complete, go to step 13.
  6. Repair the A/C compressor clutch concern and determine if the A/C system is operating within specifications. If yes, go to step 8. If no, go to step 11.
  7. Repair the low engine temperature concern. When the repair is complete, go to step 13.
  8. Inspect for correct operation of the recirculation door. If the door is operating correctly, go to step 13. If the door is not operating properly, go to step 12.
  9. Repair the air delivery concern. When the repair is complete, go to step 13.
  10. Repair the heating concern. When the repair is complete, go to step 13.
  11. Repair the A/C performance concern. When the repair is complete, go to step 13.
  12. Repair the recirculation door concern. When the repair is complete, go to step 13.
  13. Operate the system in order to verify the repair. If the system is operating properly, the procedure is complete. If the system is still not providing proper defrosting, repeat the entire test
. Noise from the HVAC Module
  1. Start the engine. Cycle through all blower speeds, A/C mode settings and temperature control settings. Determine the type of noise, whether it is a scraping, popping, ticking, clicking, chirping or groaning, or an air rush or whistle. Is a scrape or pop noise evident when selecting modes or temperature settings? If yes, go to step 5. If no, go to the next step.
  2. Is a tick/click, chirping, groaning or scraping noise present, but decreases as blower motor speed is decreased? If yes, go to step 5. If no, go to the next step.
  3. Is an air rush/whistle noise evident in all modes but not all temperature settings? If yes, go to step 5. If no, go to the next step.
  4. Is an air rush/whistle noise evident only in defrost or floor mode? If yes, go to step 5. If no, examine for other sounds, repeat step 1.
  5. Remove the I/P trim pad. When complete, go to the next step.
  6. Inspect the airflow doors for proper operation and the ducts for obstructions or foreign materials. Were any of these conditions found? If yes, go to step 9. If no, go to the next step.
  7. Inspect the mode and temperature doors and seals for warping or cracking. Are the doors in normal condition? If yes, go to step 9. If no, go to the next step.
  8. Replace the appropriate door and/or seals. When the repair is complete, go to step 10.
  9. Remove any obstructions or foreign material found. When the repair is complete, go to step 10.
  10. Install the I/P trim pad. When complete, go to the next step.
  11. Operate the system to verify the repair. If system operates without noise, the repair is complete. If noise still exists, repeat the entire procedure.
Jul 21, 2010 | 1999 Chevrolet Astro
Where i can found the ac filter, bacause i want to replace. tnks
AIR FILTER
DESCRIPTION
A dust and odor air filter is standard equipment on
models equipped with the three zone temperature
control systems. The filter element is the
same size as the front air conditioner evaporator to
ensure ample filtering capacity. A removable door on
the bottom of the front HVAC housing below the
glove box provides easy access to the filter element
for replacement. The filter should be checked and
replaced at least once every 24,000 km (15,000 miles)
and checked if heater-A/C system performance seems
lower than expected.
REMOVAL
(1) Locate the air filter door on the bottom of the
lower HVAC housing just outboard of the passenger
side of the instrument panel center stack.
(2) Slide the air filter door latch toward the rear of
the vehicle until it engages the opened stop on the
door.
(3) Pull the air filter door straight downward to
disengage it from the air filter opening of the lower
HVAC housing.
(4) Use your fingers to reach through the air filter
opening of the lower HVAC housing far enough to
grasp the air filter.
(5) Pull the air filter straight down and out of the
HVAC housing.
INSTALLATION
(1) Note the “Airflow” directional arrow imprinted
on the foam seal around the frame of the air filter.
This arrow should always be oriented towards the
center of the vehicle.
(2) With the air filter “Airflow” arrow properly oriented,
carefully slide the filter fully upward into the
HVAC housing through the air filter opening.
(3) With the latch still positioned against its
opened stop, reinstall the air filter door onto the
lower HVAC housing air filter opening.
(4) Slide the air filter door latch toward the front
of the vehicle until it hits the closed stop on the door.
Good luck
Dec 22, 2009 | 2004 Dodge Caravan
04 Tahoe AC blows hot air on drivers side but resets if restarted
A educated guess I would have to say there is a problem with HVAC control module ! electronics you know ! But that's not the way to do things ! There could be codes stored in the module. The Chevy dealer my have a reflash bulletin for this problem . Then can reflash , reprogram the control module ! The first place to start is checking for codes in the HVAC module.
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal.
Air Temperature Sensors The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
Ambient Air Temperature Sensor
Inside Air Temperature Sensor Assembly
Inside Air Temperature Sensor Assembly-Auxiliary
Upper Left Air Temperature Sensor
Upper Right Air Temperature Sensor
Lower Left Air Temperature Sensor
Lower Right Air Temperature Sensor
Upper Air Temperature Sensor-Auxiliary
Lower Air Temperature Sensor-Auxiliary
A signal and low reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40?° to +101?°C (-40?° to +215?°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside air temperature sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
If the HVAC control module or auxiliary HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted air temperature value. The default value for the ambient and inside air temperature sensors will be displayed on the scan tool. The default value for the duct air temperature sensors will not be displayed on the scan tool. The scan tool parameter for the duct air temperature sensors are the actual state of the signal circuit. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is corrected.
The ambient air temperature sensor mounts underhood and can be affected by city traffic, by idling, and by restarting a hot engine. Therefore, the HVAC control module filters the value of the ambient air temperature sensor for temperature display. The ambient air temperature value is updated under the following conditions: Or you can just buy a new control module an hope that it fixes it. $89.00 at www.partsgeek.com
Search from over 10 Million Auto Parts
Sep 18, 2009 | 2005 Chevrolet Silverado
Air conditioning unit
On a "Non Heat Pump" unit, icing of the pipes is not good. It is an indication that you either have a low freon level (Charge), low load, wrong superheat.
A low load usually means, in this case, something wrong with the air flow. Clogged filter, wrong fan speed, something blocking the return air grill, like a chair/ blanket, etc.
If low on charge, the evap (Indoor Coil) will ice up and the ice will then slowly creep along the pipe untill it gets to the outdoor unit. This is really no good. Air cannot go thru solid ice so naturally there is no cooling happening.
If a company replaces the outdoor unit (Condensing Unit), there is no warranty on the indoor unit. I do not know of any company that will repair an indoor coil (Evap). Just not smart money. They have to capture the freon, open the system, make the repair, ensure the correct level of freon is in the system, and most time, add a filter/ dryer for additional filtering and drying of the freon. With all that, no one is going to patch a leak on an old coil because if it leaks now, it's going to have another soon. You'll just be chasing leaks and spend money after money. Hope that makes sense. HVAC companys have to follow the EPA rules too. Leaving a system leaking above a certain percent of it's total charge is a major no-no. They will not do it.
Hope this helps clear up a few things and good luck.
Jul 11, 2008 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
