Question about SanDisk Sansa e250 MP3 Player
Worked only once
Worked only one time with 15 melodies, when I tryied to add more it happend the same thing, same eror, and I followed the steps again ,this time I syncronised 178 songs without adding later and it sync only 5 songs from 178
  • 8,596 Answers
You probably synced songs that were in the wrong format - see my 2-part article under my profile on song formats for a more details explanation. Short answer: convert all osngs to mp3 format
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 03, 2008
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
I have a desk top pc installed on d-Link ADSL2+. I am now tryiing to add a laptop .Not having much success . Do I need adapters for pc and laptop?
No,all you need is a Ethernet cable.
Back of your Router you have Four ports so that you can connect it to four different computers.
Once you have connected the Laptop with a hard wire you can configure it work in a wireless state.
Click the link below and follow the steps to configure the wireless setup on your laptop.
http://www.corenetworkz.com/2009/11/how-to-configure-d-link-wbr-2310.html
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I do not utilize yahoo on my internet explorer at all. Yet this morning I was unable to access the internet. The reason read as follows: internet explorer has encountered a problem with an add on and...
The easiest way to fix this problem is to uninstall the Yahoo Toolbar using add/remove programs. Once that is done, your internet should be working again. If you want the yahoo toolbar, you can go back to yahoo.com and download/install it again, and it should work fine.
Today, 12/15/10, I have had to do this on 5 different computers, so my guess is something in the toolbar was updated, and is causing the problems. Reinstalling the toolbar after removing it did not cause further issues.
Neil
Dec 15, 2010 | Yahoo
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
155.0.0 code eror
This is a Windows scanner driver error and the resolution is to download and install the latest driver from Canoin Support for your opertaing system.
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
2002 Isuzu Ax
change fuel filter, add can of SEAFOAM to gas. Trust me on this. EGS(ethanol gas syndrome)
Sep 04, 2009 | Isuzu Axiom Cars & Trucks
Sansa e270 refresh database
Go under settings and change USB Mode to other choice. Then format. After formatting change back to original setting. I had same prob. Tech support told me to do this and it worked. Have had no problem since.
Jan 07, 2008 | SanDisk Sansa e260 MP3 Player
Microsoft wireless multimedia keyboard 1.0A
I suppose you should reset the keyboard and mouse and maybe the access point itself. Try find small buttons on each devise and press them AT THE TIME. You may need somebody's help. Those buttos can by hidden under mouse and keyboard and should be on the top of the access point. This depend on the model, so please reffer to a manual.
Oct 21, 2007 | Computers & Internet
ITS FROZEN
My first idea was that the software in the MP3 player caused it to hang. Although I have no experience with this player in particular, try the following: - Open the lid on the back side and take out the battery - Wait a minute or two - Turn it on - Try if it works now
Dec 05, 2006 | RCA Lyra RD2765 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
